Projects Rear axle width
Discussion in 'The Hokey Ass Message Board' started by long island vic, May 23, 2020.
  1. long island vic
    long island vic
    Need at backing to backing also spring .center center
  2. long island vic
    long island vic
    Make that 39 chevy take two
  3. Hnstray
    Hnstray
    from Quincy, IL
    You asked for “backing (plate) to backing“......To my knowledge, ‘37 thru ‘39 Chevy rear axles are the same. My ‘37 axle is 59” from wheel mounting surface (WMS) side to side. I am not at home presently and cannot measure between the backing plates until I return.
    However, a close guess would be about 53” +/- a little. Generally, the WMS to WMS is considered the most useful dimension when determining axle width. The spring center bolt to center bolt is 42.25” +/- .25”. I am in the midst of replacing my ‘37 axle/torque tube with a later model open driveline and TCI springs.
    Hope this helps.
    Ray
    dan c and gimpyshotrods like this.
