Hot Rods rear axle
Discussion in 'The Hokey Ass Message Board' started by nnunky, Aug 19, 2019.
  1. nnunky
    nnunky
    i have a 39 ford pickup and going to change the rear axle as i am in the
    process of putting in a 302.when i measure the width am i measuring from the back of either side of the backing plate?i need to find a suitable donor axle if anybody can help suggest a suitable replacement.its pretty much a standard 302 so not producing alot of hp.
  2. embyman68
    embyman68
    I find it much more useful to measure from wheel mounting surface of drum to wheel mounting surface so track can be matched exactly.
    Hnstray and Just Gary like this.
  3. manyolcars
    manyolcars
    embyman got it right.If you use the 1946-47 3" wider bed, you can fit a wide range of 9" Ford pickup axles. I have driven my 39 every day for 17 years
  4. Doublepumper
    Doublepumper
    from OR-WA, USA
    A 8.8 out of an Explorer should fit fine. You'll have several gear choices, trac-lock and disc brakes. They are easy to find and prices are cheap.
  5. trollst
    trollst
    8.8 out of a ford ranger pickup is perfect and cheap. Also plenty strong for a V8.
