Technical Rear Bias Ply
Discussion in 'Traditional Hot Rods' started by sbf001, Mar 12, 2016.
  1. sbf001
    sbf001
    from New York
    Hello
    I have a 30 model a frame with 3in z. And 4in drop axle. I have 28 3/4in bias plys on the front would a 31in be ok to run on the back?
    Thanks
  2. clem
    clem
    Most run that height tyres.
    Should be okay, but more details needed.
    All relates to diff ratios and gearbox ratios.
  3. Jalopy Joker
    Jalopy Joker
    post pics of your ride
  4. sbf001
    sbf001
    from New York
  5. 19Eddy30
    19Eddy30
    from VA
    Are you asking if you can run a taller tire on rear , Biger then front ,
    Yes !
    As long as it a bias also ,
  6. sbf001
    sbf001
    from New York
    I just have roller Tires on there now. I have 28 3/4 just wondering if I can run a 31in on the rear. Have to gl*** wheels wells back in previous owner cut them out.
    Thanks
  7. Tim
    Tim
    from KCMO
    Short answer: yes.
  8. lurker mick
    lurker mick
    Personally, I would think of running a smaller front tire, 28 3/4" is a fairly tall tire, not sure you'll notice that much difference with a 31" rear tire if you're looking for a rubber rake.
    Mick
  9. just read some threads, most people run a 550-16 or 600-16 up front and 700-16 or 750 -16 out back I have 600's in front and 750's on rear I think the 750's are around 31" tall. so the answer is yes.
    John Heckman likes this.
  10. IMG_6029.JPG .............14" rear Z, 12" stretch 560x15 bias frnt, 700x16 bias on rear(note) run 28-32 psi all the way around on bias ply tires to eliminate squirreling)
  11. 14' rear Z, 12' front stretch.......560x15 frnt,700x16 all bias ply (note: run 28-32 psi in all to minimize or eliminate squirreling with bias ply tires) Handles great.
  12. sbf001
    sbf001
    from New York
    Is a 4.50 a 25in overall diameter? I am thinking about 25in on front and 28 3/4 on the back
  13. I believe a 4.50 is 24" in diameter. it works really well with a 7.00x16 (30" approx.) on the rear. 7.50's start to get close to 31". There is a lot of open space at the back of a roadster...fill it up.
  14. sbf001
    sbf001
    from New York
    I will just run my 28 3/4 on the front and get 31in for the back. Thanks for all the replies.
  15. Boolajosh
    Boolajosh
    from Monrovia
    4.50/4.75x16 front, 7.50x16 rear.. and I only have like, a 2"z
    Sent from my SM-G920V using H.A.M.B. mobile app
  16. verno30
    verno30
    If the bolt patterns are the same, I would put the front tires on the rear and go with a 4.75-5.25 on the front. What axle ratio and transmission are you running? Truthfully, that may be the deciding factor.
  17. sbf001
    sbf001
    from New York
    I have pontiac 2spd and 3:73 gears s10 rearend
  18. init1
    init1
    Run 7:50 16's in the rear and 5:50's on the front. That combo looks great.
  19. verno30
    verno30
    ^^^^^Agreed. Run your current tires in the back and get some smaller rubber for the front.
