rear brake drum Q, quick
Discussion in 'The Hokey Ass Message Board' started by avenue, Sep 30, 2007.
  1. avenue
    avenue
    I'm in the driveway trying to pull the rear drums off my 64 galaxie. stupid question, maybe, but what do I need to know to get these things off so I can finish up my brake work?
    thank you.
    (search was too broad for any help)
  2. squirrel
    they can get stuck either on the shoes, or where the drum fits over the end of the axle. For the shoes, back off the brake adjustment. If the drum is stuck to the axle, try a penetrating oil, and whack the axle end dead center with a BFH. be careful.
    If that doesn't pop it off, try some heat on the flat part of the drum, it might expand the hole enough to come off the axle.
    there are threads about this subject, if you search for "stuck drum"
    http://www.jalopyjournal.com/forum/showthread.php?t=171369
    for example
  3. avenue
    avenue
    thank you for the help. much appreciated
