Technical Rear brake flex hose rotates
Discussion in 'The Hokey Ass Message Board' started by Crotty 32, Sep 27, 2022.
  1. Crotty 32
    Crotty 32
    First time builder here. I am at mock-up phase and working on plumbing my brakes. I have all the parts, pieces, and tools to get it done, but I’m stuck thinking about the rear brake flex hose. Here is a pic of the setup so far:
    Question is, when the “T” on the axle moves up and down with suspension travel, the hose rotates about 15-30 degrees within the bulkhead tab on the frame.
    Here is the bulkhead tab and clip that I’m working with (all Speedway parts).
    DC99DB1C-55B8-4E22-B80F-994A8C6DCABB.jpeg 9181301B-C3EC-4F9E-B82C-D31009A5D1C0.jpeg
    I’ve never done this before and I was not expecting the hose and hardline attached to it to rotate within the bulkhead like it is. What are the thoughts of experienced HAMBers?
    A. It’s fine as-is. Rotation is expected and the adel clamps will prevent/limit rotation once all installed.
    B. The bulkhead and/or axle mounting locations are not acceptable - attempt to find new location(s) so the hose will not rotate.
    C. The bulkhead clip should prevent rotation. Either the clip setup is faulty or a bit of fabrication is needed to ensure the hose will not rotate within the bulkhead.
    D. Other ideas?
    I appreciate any and all feedback.
    Rickybop likes this.
  2. hemihotrod66
    hemihotrod66
    Old ch***is clips were made like a socket to keep the hose secure....Your tabs probably just have a round hole in it....Go online to Rock Auto and check out the brake hose ends and you will see how they keep from rotating...
  3. squirrel
    show us a picture of the end of the hose in the mounting tab, but no clip, so we can see what it looks like. Many hoses have some type of shape that prevents them from rotating, if the tab has the correct shaped hole.
    A thicker tab may help, if there is no such locating thing on the hose. So the clip has more tension
    Jagmech and hemihotrod66 like this.
  4. Crotty 32
    Crotty 32
    Here is a pic of the dis***embled hose, mounting tab, and clip. It’s just a circle all the way around…no locating flat spot or anything like that.
    Further reference, the parts are speedway and claim to be compatible with each other.
    ABE33985-CC58-4B58-BEC9-628F004538CE.jpeg 8A5E1400-1091-4BE3-B073-233A0FDC62E9.jpeg
  5. squirrel
    looks like one of the round ones.
  6. Mr48chev
    If it were me I'd locate the end of the hose that goes on the axle where I want it and secure it and then using the end of the hose that goes though the tab as a guide, mark a couple of spots (or more) to weld on a bit to create a flat that will keep the hose from turning. Just a bit of weld and file to fit and done.
    I've always snagged the brackets/ tabs off door rigs that I s****.
    Crotty 32 and olscrounger like this.
  7. Jagmech
    Jagmech
    Once the solid brake line fitting is tightened into flex hose, any twist should occur in hose portion, behind crimp only. Yes most OEM hose and tab ***emblies have a index tab or irregular shape to locate these components to prevent rotation. However I ***ume you are seeing the metal line twisting to some degree with the movement. I solved the problem with a '68 Chevy p/up rear hose , 14" long, and modified the location tab to match hose end shape. I don't see enough material on the your hose end to file a "flat" and add them add a weld bead to hole in tab and file to fit, but you could try.
    Bandit Billy and Johnny Gee like this.
  8. NoelC
    NoelC
    The problem appears to me to be the wrong hose being used in that location.
    I could be mistaken, but that hose and your use of it is the problem. It doesn't belong there as you have it shown. That's my opinion.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    So location/routing as apposed to a hose indexes it’s self is the issue?
  10. NoelC
    NoelC
    To be clear as crystal, that hose should be positioned to drop down from above then it isn't affected by rear end movement.
    VANDENPLAS likes this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I guess the physics of how front spindles move makes that wrong as well?
    seb fontana likes this.
  12. RICH B
    RICH B
    I'd probably run the steel line back and around the corner some, mount the tab on the crossmember, and mount the hose close to the center of the axle. With hose in an "L" shape it can move up and down without trying to rotate.
    You could also mount the hose further forward on the frame so it ran straight to the axle and just had to move up and down.
    Crotty 32 and NoelC like this.
  13. NoelC
    NoelC
    alanp561 and Crotty 32 like this.
  14. Jagmech
    Jagmech
    Noel brings up a good point , relocation of tab/ union point more towards rear ,may eliminate twist problem, try and see what happens, at least this guy is paying attention to details to prevent problems down the road.
  15. RICH B
    RICH B
    Kinda like this.
    Nailhead Jason and NoelC like this.
  16. gene-koning
    gene-koning
    Nobody else was concerned about the axle housing rotating 15 degrees as it moves through the suspension travel and how that might effect U joint life?
  17. Rickybop
    Rickybop
    Your ears must have wobbled, Gene. It's the fitting at the end of the hose at the frame that's rotating a little bit when the axle moves straight up and down.
    Once again, I learn one of the teeniest tiniest little things from you guys... but which are so important.
    And I'm sure will save me grief.
    Thank ya. Thank ya very much.
  18. gimpyshotrods
    gimpyshotrods
    Put a weld bead where the red dot is. File it so that it sits up against one of the wrench flats on the hose fitting.
  19. Happydaze
    Happydaze
    Agreed, but it might be easier to place a small piece if steel to provide a straight edge against the hex of the brake line thus enabling the added piece to be welded to the tab away from where the action is. Saves filing welds straight etc.
    Chris
    Crotty 32 likes this.
  20. TRENDZ
    TRENDZ
    The hose mount on the frame needs to be directly over the mounting hole in the axle.(or vice-versa)
    Brake hoses are not meant to be twisted.
    Nailhead Jason likes this.
  21. KevKo
    KevKo
    from Motown
    Don't the front brake flex lines twist with suspension travel and steering?
  22. Crotty 32
    Crotty 32
    Thank you all for the suggestions and ideas. Seems like my gut instinct was right and the hose should not be rotating at all inside the bulkhead fitting.
    I would expect the flex line to have some twisting capacity in the hose between the crimps, though. I ***ume as long as the hose ribs are parallel or “in-line” and not looking like a Twizzler, it should function well for its entire intended service life. Is this a wrong ***umption? Should the hose not be subjected to ANY rotational forces? Just lateral and/or horizontal movement?
    THE FRENCHTOWN FLYER likes this.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    A few have mentioned on this all ready. Think what a front brake hose is subject to.
    Jagmech and gimpyshotrods like this.
  24. woodiewagon46
    woodiewagon46
    from New York
    Crotty, first let me compliment you on your beautiful workmanship on your project. As for your question, I think that you are over thinking your problem. You are going to have minimal up-down movement, probably only an inch or two and I do not think that it will affect anything. I would build it just as you have planned, (almost a copy of how I plumbed my Deuce roadster, except I used braided flex lines) with zero issues in over 50,000 miles.
  25. nobby
    nobby
    so you do plan on running a ford oem style vent bolt?
    have you managed to buy one yet?
    also where are the inputs to the wheel cylinders?
  26. Crotty 32
    Crotty 32
    Thank you! The credit must be directed to the frame builder Blackboard Hot Rods for what you see in the pictures of this thread. I am just trying to keep up the rest of the build to his caliber as best I can and ensure this rig is as safe and reliable as can be.
    I appreciate your real-world experience with this flex set-up and it definitely comforts me knowing that you’ve had so many trouble-free miles.
  27. Crotty 32
    Crotty 32
    I was not planning on using a vent bolt for the flex hose mount - just going to weld on a 7/16” bolt as a stud. I kinda like the idea of being able to stick my head under the rear end after a drive and if I see any moisture from that flex hose mounting point, I know it’s brake fluid and not from the axle vent.
    The rear drum brake cylinders are located at the top of the axle, angled towards the rear of the vehicle.
  28. inthweedz
    inthweedz
    I agree with 'woodiewagon46', your suspension is only working aprox 2'' at most times, so it shouldn't be a problem..
    If it does concern you, how about drop a bit of weld on the mount hole, file it flat, and then file a corresponding flat on the hose (aligning it in the right direction)..
  29. Crotty 32
    Crotty 32
    Thanks again for all the insight. I am going to modify the bulkhead as suggested in order to prevent the slight rotation of the hose. I may try and find a better location for the bulkhead and axle mount as well. I’ll revert back with pics of progress eventually (I work real slow….)
    Johnny Gee likes this.
  30. Atwater Mike
    Atwater Mike
    Very impressed: Agree, however, with the 'L' shape for hose theory: If the front brake hoses MUST twist from steering left & right, then they must.
    If, however, a simplex bend in the hose that wouldn't force a twist would be a reachable (and preferable) option.
    The already supreme execution of design/application having been accomplished dictates continued perfection.
    (Whew! That sounded pretty...'final'.)
    Budget36 likes this.
