Technical Rear Brake Identification
Discussion in 'Traditional Hot Rods' started by Adrenaline, Jul 10, 2023.
  1. Adrenaline
    Adrenaline
    Im hoping someone can identify this brake setup so i can more confidently take it apart and service it. Any help would be greatly appreciated. Reaar Brake 1.jpg Rear Brake 2.jpg
  2. alchemy
    alchemy
    There are only two bazillion different Ford pickup brake variants, so someone should have an answer for you very shortly.
    Truthfully, I think it looks like an early F-1. But maybe you could get some measurements or maybe find a number on one of the components?
    warhorseracing likes this.
  3. Tim
    Tim
    from KCMO
    What bolt pattern are the wheel studs?
  4. Adrenaline
    Adrenaline
    Yeah, but im looking for at least a ball park answer. lol
    Nothing on them that i can see.
  5. Adrenaline
    Adrenaline
    5x5.5
  6. Jmountainjr
    Jmountainjr
    What's the number on the brake drum in the first picture?
  7. lostone
    lostone
    from kansas
    Pull the drum and see what's under it...
    dmar836 and squirrel like this.
  8. squirrel
  9. junkman8888
    junkman8888
    With a 5 x 5.5 bolt pattern the best guess is F-1 pickup or '49-'51 Mercury.
  10. dirt t
    dirt t
    I'm probably all wet but my first thought was chrysler,Dodge.....
  11. nobby
    nobby
    i think its 49-55 ford f100
    the axle shaft centre is the give away
    as its a dana 41 shaft
    also the rear bearing housing is dana
    the brakes should be
    11 by 1 3/4''
    so you can add the self adjusters to them while you are at it.......
    you can do whats been done as an f100 rear axle is 61 .25 inch long
    i think they have chopped the tube off and fitted it to a banjo.
    there being enough meat after the splines to respline
    the axle i had also had them there little slits in them - they are not debris ejectors, but feeler guage insertion slits to gauge the shoe wear
    as stock they don't have self adjusting cables.
    you can also tell they have not been converted to self adjustment as there would be two slits where the rubber insert goes to fit the flat screw driver to adjust.
    its nothing to do with i don't' need self adjusters, i will adjust them my self
    its about them both being perfectly adjusted to balance them side to side with wear , do you havn't manual adjusted them incorrectly and the car dive left or right under braking
  12. nobby
    nobby
    if you like.....
    the give away of it being dana 41 is
    the bolts that hold the backing plate come from the rear, they have a knurled shaft much like a wheel stud and are pressed in - unlike the later ford t - bolt style
    if doing the bearings they are 3 . 125 - same as big bearing ford 9''
  13. nobby
    nobby
    the other way to gauge it is,
    if you are running f1 front brakes at 11 by 2''
    then the person that built that car really knew what he was doing as you have the perfect one to .75 front to rear brake bias - like the factory setting.
    why you wouldnt go to all that trouble and not fit the self adjusters though?
  14. dirt t
    dirt t
    Looks chrysler type.
    Does it say ford on the backing plate?
  15. seb fontana
    seb fontana
    from ct
    Big Ford and Torino type is 3.150 bearing OD.
