Hot Rods rear brake lines
Discussion in 'The Hokey Ass Message Board' started by 4ford, Nov 27, 2018.
  1. 4ford
    4ford
    from Eagan. Mn
    is there anyone that has pictures of a ford 9inch with the brake lines plumbed shoe brakes. just need some ideas on how to run lines.
    thank you!!!
    mike
  2. 4ford
    4ford
    from Eagan. Mn
    and sorry I should have said what kind of car its on 1941 ford coupe with leaf springs and standard brakes
  3. olscrounger
    olscrounger
    Done a bunch of 40's this way. factory type block that bolts to rear end for lines with a long hose (factory part). Brake line down dr side rail with a support bracket for the hose.-Make sure hose is long enough to not become tight when car is jacked up.
  4. 64Belvedere
    64Belvedere
    from Alabama
    Not sure if this is what you are interested in, but hopefully this helps a little. This is the 9 inch in my '66 F100 with repo hard lines that are not a perfect fit. The original lines had a tighter curve around the center section. Ignore all the rust. 20+ years in a dirt floor barn left a mark...
  5. 4ford
    4ford
    from Eagan. Mn
    that's what I am looking for some ideas!!! thanks
  6. RICH B
    RICH B
    Brake lines on the 9" in my coupe.
    olscrounger and Asphalt Angel like this.
  7. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Early on in my '31 build.
  8. 4ford
    4ford
    from Eagan. Mn
    thanks Rich !!!
