hey guys- can some of you post some pictures of you coil spring and radius arm rear end setups? I am in the process of setting mine up and would like something to compare it to. really looking for location , geometry not really measurements. just to make sure I did not miss anything before I weld it in. Thanks Joe
its a 73 Camaro 10 bolt under a 31 chevy sedan with the rear 12" cut off the frame. I always do leaf spring rears so this is new to me. just want to look at some others to see if my position of the springs and bars are close.( both are mounted inside the frame rails) the springs look like they may be to close to the center of the rear end. but not sure that matters. thanks Joe
