Hot Rods rear diff noise
Discussion in 'The Hokey Ass Message Board' started by Huckster59, Jul 16, 2024.
  1. Huckster59
    Huckster59
    ok i removed the trash bars or solid traction bars. rode to tight and rough. got all back together. ride tested. got on it a little. get a vibration and rumble out of rear of car. these bar were mount to u/bolts and clamped tight on front of spring. could this have taken the arch out and when i got on it the resr diff might be dipping? 40 ford leaf spring rear. also leaning a inch on l side.
    B03D6866-F4A1-4749-8C37-EEC13EEB682B.jpeg 3C1BFBDD-B5D6-452D-A328-BBB94EFCFA8C.jpeg
  2. BJR
    BJR
    Does the pinion angle match the rear of the transmission shaft angle? At ride height.
    jaracer likes this.
  3. squirrel
    how tall are the lowering blocks? :)
    Pocket Nick and twenty8 like this.
  4. Huckster59
    Huckster59
    did not add any lowering blocks going to crawl under and see what angle is today
  5. Huckster59
    Huckster59
    so do i pick a flat spot on diff and on trans. muncie 4 speed. 62 gm rear end
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Measure vertically at tail housing at out put end and vertically at rear end pinion.
  7. jaracer
    jaracer
    I've found it easiest to measure on the u-joint caps. I use a Snap-On socket that just fits the cap. I've already checked the socket for being square. Go from cap at trans to shaft and then shaft to cap on diff yoke. The angle between the shaft and either yoke shouldn't be more than 5 degrees (3 is better) and the trans cap and diff cap should be within 5 degrees of each other. The weight of the vehicle has to be on the suspension when you do the measurements.
    Also you must realize that the differential will try to move upward on acceleration changing the rear angle. If the vibration is only on acceleration, you may want to shim the rear end to point the diff slightly down. If it vibrates on both acceleration and deceleration, something is lose allowing the rear to move around.
    Johnny Gee likes this.
  8. Huckster59
    Huckster59
    did not change the angle. just removed lower plates for traction bars
  9. Huckster59
    Huckster59
    but it did vibrate some before. ok measured rear. 9deg. driveshaft is at 0 deg. front yoke is 5 deg.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Rear yoke is pointing up or down? Trans I’m sure is down ward?
  11. alchemy
    alchemy
    Having 4 degrees difference between the trans and rear seems like too much. Zero degrees difference would be best.
    SS327 likes this.
  12. Huckster59
    Huckster59
    up on the rear. the mounts on rear diff housing are ******ed up pretty good. rigged. think i’ll remove and install new mounts and do it right. get her zeroed in with new springs since she’s sagging on l side
    seb fontana and TA DAD like this.
  13. tim troutman
    tim troutman
    last time I had a problem like this I raised the trans mount up trying to fix the angle before I realized I had a worn ujoint .replaced it smooth as new
  14. twenty8
    twenty8
    How much spring wrap is happening when you are into it? Could be adding too much extra pinion angle.
    Maybe that's why the traction bars were on there...???
