rear e brake for a body gm
Discussion in 'Off Topic Hot Rods & Customs' started by c/h, Jul 6, 2024.
  1. c/h
    c/h
    from iowa
    bought a kit from speedway for my t bucket no e brake. Found out to p*** inspection i need a e brake.
    speedway dont carry the calipers i need and im having a hard time finding what i need so thought id post see if someone knows what i need.
    my brackets are for full size d52 type gm caliper for 69-72 Chevelle 73-77 a body 1969-1981 Camaro .
    my bracket is designed for large gm caliper 7"inch mount width.
    rear end is a olds Pontiac my bolt pattern is 5 on 5 .thank you
  2. gimpyshotrods
    gimpyshotrods
    Pre-1979 Cadillac Eldorado.
    1973-1978, I think.
    You will need to source levers, and make the cable brackets.
  3. gimpyshotrods
    gimpyshotrods
    You're in luck. The actuation hardware is being reproduced.
    https://www.greatlakeoffroad.com/pr...eldorado-e-brake-caliper-parts-actuating-kit/
    You would just need to buy a pair of thin nylock nuts.
    Lokar stuff hooks right up to these. Easy peasy.
    Most chain auto parts stores can get the calipers.
    They take the same pads as the front ones that came in your kit, and they bolt directly into the same brackets.
    jazz1 likes this.
  4. Mr48chev
    Those are 75/78 Eldorado. The only one I know of that sells them with the levers new is https://www.ruffstuffspecialties.com/R2262-A.html I need to order a pair for my 71 3/4 ton that I am putting disk on the rear.
    The off road/crawler brigade running 3/4 ton axles usually run the front calipers like came in your kit but need the park brake to p*** inspection for highway use.
  5. Mr48chev
    I'm saving that link that Gimpy showed. Over the counter prices for the calipers is high though.
  6. gimpyshotrods
    gimpyshotrods
  7. gimpyshotrods
    gimpyshotrods
    $55+core, each.
  8. sdluck
    sdluck
    We put small rotor on the diff yoke and put a go kart caliper on it.
  9. gimpyshotrods
    gimpyshotrods
  10. c/h
    c/h
    from iowa
    man you guys always have the answers
    gimpyshotrods likes this.
  11. c/h
    c/h
    from iowa
    called on the AutoZone caliper special-order item and none available
    napa said no way he can get a set.
  12. gimpyshotrods
    gimpyshotrods
    AutoZone shows them in-stock online.
  13. c/h
    c/h
    from iowa
    my store here in ankney says no but i like your store happen to have a location or where you looked it up
  14. Unkl Ian
    Unkl Ian
    IIRC, Wilwood makes a separate Mechanical Emergency Brake Caliper.
  15. dirt t
    dirt t
    I missed it, what rear end do you have?
  16. c/h
    c/h
    from iowa
    olds Pontiac
    5x5
  17. gimpyshotrods
    gimpyshotrods
    I used the website.
    I even set the store location to Cedar Rapids.
  18. c/h
    c/h
    from iowa
    went to 3 stores none in stock called cedar rapids 3 store nothing. Think il gut it and start over
