Rear End +/- 60 inches
Discussion in 'The Hokey Ass Message Board' started by oldjeepdog, May 27, 2009.
  1. I'm currently running a 56 1/2 inch wide rear end on my 66 Chevy 1/2 ton. I am using newer GM wheels & a 1.5 inch six lug custom spacer on each side.
    Does anyone have know of a web source that lists rear end dimensions? I'd like to move up to a 60 inch wide rear end, maybe even getting disc brakes, 3.50 ratio & posi.
    Thanks
    Old Jeep Dog
  2. sharkfoodjohnny
    sharkfoodjohnny
    Rear ends from a 67-69 Camaro and 55-57 Chev are exactly 60". Later Camaro rear ends are 62".
  3. hotrod-Linkin
    hotrod-Linkin
    go to carnut web site and click on tech...they have a bunch of rearend widths...i would do it for you but i'm tired of posting the info every week because some guys can't see the search function...
  4. Mr48chev
    I think that a 73/80 or so 4x4 will probably work if you are running six lug wheels.
    Check your pm's
  5. Retro Jim
    Retro Jim
    1984 or 85 Ford Mustang rear is around 57" and posi !
  6. hotrod-Linkin
    hotrod-Linkin
  7. TomP64
    TomP64
    from Vancouver
    Yikes, some bad information here. The 84-85 Mustang is 60" but certainly not something you use in a pickup truck. Cast-in 4 link brackets and skinny tapered axle tubes. A 73-80 Chev 4x4 is way too wide.
    A 55-57 Chev rear end is something to swap out of vehicles , not in.
    The Camaro/Nova 10 or 12 bolt will work.
    Other types that can be used with different wheel patterns are a 67-70 Mustang 9" or a B body Mopar.
  8. Retro Jim
    Retro Jim
    My mistake , your're right . I did get that for my 55 Ford . I was thinking of my 38 Ply p/p that has the shorter rear that is 57" and I do have a Ford rear for that also . Can't remember what it's out of but I think a Maverick or something along that line .
  9. Also, explorer rear ends are 59.75" wide and pretty beefy, but a 4.5" bolt pattern.
  10. 6deucecaddy
    6deucecaddy
    Get a 67-69 Camaro 10 bolt w/ 5 lugs and take the axles and drums to a machinist and have them redrilled for 6 lug. I got a 3.08 gear which is a little more freeway friendly. That's what I did last week!!!
  11. May Pop
    May Pop
    IH Scout is 58" ,Jeep cherokee is about 60" Old style full size Wagoneer or cherokee is also about 60". The Scout and full size Cherokee are both Dana 44s. Any gear or posi,lockerand spool available. Full size Cherokee also is 6 lug. Scout 5on5.5 small cherokee 5on4.5
  12. '73-77 monte carlo, look into it.did it, loved it
  13. Scorch67
    Scorch67
    from Omaha, Ne
    60" on the 1st gen camaro, 61" on the 2nd gen just went and measured one...
    I think 9"ford from a 69-73 mustang or cougar is 60" or 61" also
