If there is a thread about this already, please direct me to it.... I have a 1939 Ford Sedan....the diff was changed out years ago Has parallel leafs with a ?????? rear end......pepper tree install !!!! Want to go back to the orig style with the buggy spring... SO ???? I****ume any 36 to 40 Diff and Torque tube will fit ??? BUT ??? Will a 41-48 Diff also fit ??? If not ??? Why ??? I found a rear end on Craigslist, has juice brakes on it But not sure of the year..... Is there a measurement I could have them check, Or some clue that would pin it down..... BEFORE I make the drive to go and look ????? Help an old guy out here....I used to know all this stuff !!!! But now lucky to find my car keys !!!!! Any and All help will be much appreciated....
The wheel mounting surface to wheel mounting surface of the rear brake drums is 59 1/2 inches for a 1940 Ford. I know the article above says 59 1/4 but I measured and got 59 1/2 in. The OEM 1939 Ford rear will have the "wide five" bolt pattern on the drums. The 40 does not. If possible, join the AAA club near you and glean info. from a person with a 39 Ford sedan. Also, the rear leaf spring count may be different for a sedan and a coupe. Give this fellow a call.. http://www.fordbarn.com/forum/showthread.php?t=165622&highlight=1940+ford+rear+end
'42-'48 rears are 1-1/2" wider unless you go with a wheel with a deeper offset you might have some interference. '36-'41 are the same width.
