rear end dilemma
Discussion in 'The Hokey Ass Message Board' started by awin4sin, Mar 15, 2011.
  1. awin4sin
    awin4sin
    from las vegas
    hello again this is my first post on the main board. I have a 1951 chevy deluxe that i am putting a lq9 with 340 hp i have a lincoln versailles rear end. a guy here in vegas at a differential shop said the rear end cant handle the engine any suggestions on what rear end to use
  2. 1971BB427
    1971BB427
    from Oregon
  3. gibraltar72
    gibraltar72
    from Osseo Mi.
    Gee I think a lincoln Vesailles rearend is a 9 in. !
  4. FoxSpeed
    FoxSpeed
    from NorCal
    it will handle your engine no problem.. i have run a 58 ford 9", 28 spline, for 11 years, only problem was a leaky axle seal after 6 years. I run a 400hp sbc with 700r4. Hope this helps.
  5. 26 roadster
    26 roadster
    Lincoln will work, 1951 chevy track was 58.75", does your diff guy want to sell you one "more" suitable?
    an 8" will handle 340hp on street tires.
  6. Find a different rear end shop:).
  7. 53mercury
    53mercury
    Yup, no strain on that 9" at all. Find a different shop. Mike
  8. Versaille rear end is a 9" and it will easily handle that HP level, especially since you will never have enough tire on that Chevy to hook up hard enough to hurt that rear end. I'd look for a more honest shop.
  9. gimpyshotrods
    gimpyshotrods
    Probably just wants that rear end for one of his projects. Did he offer to buy it off of you or give you credit for it towards something else?
    I am curious what rear end he thinks would be stronger. Find a different shop.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    I agree,He is full of it! find another shop and run from Him as fast as you can.
  11. Timbo from Mempho
    Timbo from Mempho
    from Memphis
    Wondering if the shop guy was refering to the ratio. My Versailles rear end had a 247 gear in it.
  12. gimpyshotrods
    gimpyshotrods
    It still would hold up just fine. If anything, better. The numerically lower the ratio, the physically bigger the pinion gear is, and vice-versa.
  13. 53sled
    53sled
    from KCMO
    There are guys putting more power than that through weak 10 bolts in a lot of camaro/s10/etc. This guy is pissing on your leg and telling you it's raining.
    separate, but more important, what springs are you using? stock springs will wheel hop terribly and really f*** s*** up. especially if you add lowering blocks to the mix.
  14. rustyangels
    rustyangels
    My thoughts exactly
  15. awin4sin
    awin4sin
    from las vegas
    thanks for all the help guys . I kinda thought the same thing just new to the game. i appreciate all the help
  16. awin4sin
    awin4sin
    from las vegas
    thanks a lot for that chart man
