Hot Rods rear end help (Model AV8)
Discussion in 'The Hokey Ass Message Board' started by Ball and Chain, Nov 10, 2010.
  1. Ball and Chain
    Ball and Chain
    from Nor Cal
    My model A frame is set up for a banjo rear. Besides gear ratio, is there an advantage to usually one year rear end over the other? I will be putting everything into a quickchange. But I have a 1935, 1940, 1946 lying around.
    Thanks Kevin
  2. AJofHollywood
    AJofHollywood
    Right off the bat, I'd say go with the '40 --it's the most sensible. It is not as wide as the '46, so it will look better under a Model A, and it may also be stronger then the '35.
    If one of the diffs is a 3.78, use its gears. Especially with a quickchange, or even without. Unless you happen to have a 3.54, of course, it's the most sought after ratio.
  3. I am of the opinion that pre '37 banjos look best under an A Bone as the axle tubes are a bit slimmer and better proportioned to the A chassis. The pre '37 cars used a slightly smaller carrier bearing than the heavier 37/48 banjo equipped Fords, when the bearing size increased so did the outside diameter of the axle housing.
    I have a 35/36 housing under my A bone with a slim 33/34 torque tube.
  4. HotRodMicky
    HotRodMicky
    Looks very good Jason!
  5. Ball and Chain
    Ball and Chain
    from Nor Cal
    My (46) is the same width as my 35, so maybe it's not a 46 after all. But it does have 3.78's. But it has a different style drums then both the 40 and 35. I saw the cars that 40 and 35 came out of. So maybe I need an id on the supposed 46?
  6. Shaggy
    Shaggy
    from Sultan, WA
    It should be noted that most Qc's come with a R+P so ratio shouldnt matter, unless you are gunna machine the pinion to fit a qc
  7. Ball and Chain
    Ball and Chain
    from Nor Cal
    I have an original culver city Halibrand v8, far as I knew, they take ford guts?:confused:
  8. Ball and Chain
    Ball and Chain
    from Nor Cal
    bump
  9. Shaggy
    Shaggy
    from Sultan, WA
    The pinion on a halibrand needs a bearing on its nose for the rear cover, i belive stock ones may be modified, but i'm not 100% sure. Also there are 2 different splines of pinions on ford pinions an 8 and a 6 and and you would need the 6 spline too
  10. youngster
    youngster
    from Minnesota
    The thing with the 35 axle is they don't accept the pre '49 brakes without mods. I prefer the '37 to '40 axles. They are much cleaner looking, the '40 to '48 brakes bolt right up and are a perfect width for your A.
    Are the drums on the outside or inside of the hub on your "'46" axle?
    Ron
  11. Ball and Chain
    Ball and Chain
    from Nor Cal
    Inside.
  12. Ball and Chain
    Ball and Chain
    from Nor Cal
  13. N8B
    N8B
    Model 201 (V8) - Used the Ford passenger car gears up to 1948
  14. Ball and Chain
    Ball and Chain
    from Nor Cal
    Thanks!
