Rear end help!!!
Discussion in 'The Hokey Ass Message Board' started by BEERGODZ, Oct 30, 2016.
  1. BEERGODZ
    BEERGODZ
    just bought a 1956 mainline and the jack wagon that I bought it from left the pinion nut loose and rear end is trash! What rear end can I go with now? It was the original with 3:78 gears!
  2. F&J
    F&J
    What are your skills and tools? The guys will give better advice if you let them know.
    Easy way out is a used good rear end. The design was changed for 57.
  3. BEERGODZ
    BEERGODZ
    We have a full shop pretty much! Just having trouble finding a rear end that will fit under her! Got to be 52" from inside to inside of drums!
  4. squirrel
    ...but brakes are not all the same thickness. What is the measurement from where the wheels bolt on?
    Hnstray likes this.
  5. jimmy six
    jimmy six
    Any early Mustang 8" will fit. The width is pretty close but I think the spring purchases are a little different width. V8 Fordomatic cars had a 3.21 ratio. Good luck.
  6. BEERGODZ
    BEERGODZ
    I've got axels pulled so I'm not sure measurement outside to outside! I've got a 64 fairlane rear end but it's only 51" inside to inside!
  7. HOTRODPRIMER
    HOTRODPRIMER
    Since you didn't fill out your profile we don't know what state you are in,I phave a '54 axle behind my shop that I would let go cheap. HRP
  8. no offense , the inside of the backing plates means nothing.... the measurement of wheel mounting surface to wheel mounting surface is what you need
    i'm not familiar with a `56 Ford , but i'm sure others on here will advise what rear end to use
  9. squirrel
    measure the axles, add them together, add one inch, you'll get it pretty darn close.
    Hnstray likes this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    I do know a 64-66 Mustang is the right width for the car but the spring pads will need to be moved. HRP
  11. Hotrod390
    Hotrod390
    A 57-59 ford 9 inch is the same width and will bolt right under a 62-65 fairlane 54 1/4 inch flange to flange
