1952-59 Ford rear end help!
Discussion in 'Off Topic Hot Rods & Customs' started by noxided, Sep 25, 2011.
  1. noxided
    noxided
    Ive got a 53 merc with a 3 on the tree and a factory rear end.
    The car originally came with an overdrive.
    At one time in its life the trans was swapped out from a 55 ford with no overdrive and i cant drive over 45 mph without hight rpm's.
    Where can i find replacement rear gears for this.
  2. fxcomet
    fxcomet
    It might be easier to swap stump to stump if you can find someone looking for the steeper gears. Do you know what ratio yours is? My car supposedly has 331's but I can't confirm it until it arrives, hopefully in a week or so. If it does, I'd be open to swapping for a steeper set.
  3. parklane
    parklane
    The 53 with overdrive probably has a 4:11 gear.
  4. Retro Jim
    Retro Jim
    My 55 has 331 gears and came with a 272 w/FoM . If you find a rear make sure it came with a V8 - Y block and not a 6 cyl or a standard trans with O/D .
    personally if you are going to do a complete rear end swap , then go with an early Mustang 8" rear . They came with a 2.79 or 3.30 mostly . Can use Cougars , Mavericks , Comets rears also . If you search about 2 to 3 weeks ago I made a post on someones post about rear ends and posted all the rears with sizes and what they came out of . You might even get someone to trade a 3.31 center section for your 4.10 3rd member !
    Just a thought !
    Jim
  5. noxided
    noxided
    i dont want to swap the trans or axle, i just would like to swap out the gears.
    Yes they are 4:11
    What ratio should i go with and where can i find a 53 rear and with the correct ratio?
  6. noxided
    noxided
    Ive found a 3:90 ratio gears for the diff. is that enough to solve my
    issue?
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    3:90's only will be a little difference from your 4:11's,maybe a 5 mph gain you need to be looking for gears from a Merc that had an automatic trans,does the rear in your Merc have a back cover plate?
  8. noxided
    noxided
    it does not have a back cover plate
  9. noxided
    noxided
    what mustang axle will bolt is? the 65-66 and the 67-68 are different lengths.
  10. fxcomet
    fxcomet
    65-66. Also, the 57 Ford is the same width. There's one listed in the HAMB cl***ifeds right now.
  11. noxided
    noxided
    would a 3:31 or 3:54 help out enough?
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    3:31 would be right on for you.
  13. kustomcar53
    kustomcar53
    I have a 3.31 ratio in my '53 Ford and I love it...
  14. noxided
    noxided
    what size rear tires are you guys running?
  15. kustomcar53
    kustomcar53
    I have 6.70-15s on my car...
