rear end ideas
Discussion in 'The Hokey Ass Message Board' started by gritybyte, Nov 17, 2009.
  1. gritybyte
    gritybyte
    got a 61 galaxie cruise-o-matic with a 352, stock 3.00:1 rear end and it ****s. what do you guys think i should run
  2. manyolcars
    manyolcars
    3.00 is good for gas mileage
    what are you complaining about?
  3. barnescole
    barnescole
    3.55:1 will pep it up
  4. carkiller
    carkiller
    Get ahold of Malcome, he played with gears in his 62 with two differnt drive trains.
  5. gritybyte
    gritybyte
    3.55 sounds good to me
  6. gritybyte
    gritybyte
    nothin like a 3.00, savin gas and takin off like a school bus. lame
  7. onlychevrolets
    onlychevrolets
    keep the rear loose that C-O-M....an AOD would be nice
  8. R. Seghi
    R. Seghi
    3.73 and an AOD
  9. gritybyte
    gritybyte
    does any one know where to get a cheep transmission adapter, ex, fe to sbc or fe to diffrent ford ******?
  10. gritybyte
    gritybyte
    will an AOD bolt up to my FE 352?
  11. Hnstray
    Hnstray
    from Quincy, IL
    No, not without some sort of adapter........maybe somebody makes one, but I've not yet seen one. It would likely be easier to get an adapter to a GM automatic but don't expect it to be cheap. Either Wilcap in California or Bendtsen's in Minnesota would have them if they are available.
  12. FrozenMerc
    FrozenMerc
    Bendtsen's makes an FE to AOD / C4 adaptor. $850 if memory serves me right. Not Cheap!
  13. gritybyte
    gritybyte
    what about a c6
  14. 38Chevy454
    38Chevy454
    C6 is not an OD. What you want is lower gears like 3.73, 4.11 which will give you the acceleration improvement; combined with an OD trans, so you can still cruise the freeway without such high rpms.
  15. Mr.Musico
    Mr.Musico
    from SoCal
    run shorter tire
  16. sprdave4264
    sprdave4264
    from Arkansas
    These are all good suggestions. From experience don't run much over 3.5 ratio if you aren't going overdrive if the car is a cruiser.
  17. BeatnikPirate
    BeatnikPirate
    from Media, Pa.
    I tried the search ****on for "rear ends" but this is all I found. :mad::eek:
    (Guess I just made an *** out of myself again.:()
  18. gritybyte
    gritybyte
    i think i go with the 3.55 and keep the cruise-o.
