Technical Rear End Interchangability
Discussion in 'The Hokey Ass Message Board' started by Iron Man, Jul 1, 2016.
  1. Iron Man
    Iron Man
    Hi all. Does anyone know definitely if a '58 Pontiac rear end will bolt under a 1958 Chevy car??? My thanks in advance.
  2. gimpyshotrods
    gimpyshotrods
    Which Pontiac and which Chevy?
  3. 302GMC
    302GMC
    from Idaho
    Maybe, if they're both Canadian built.
  4. DDDenny
    Not positive but I think you may need what is called a conversion or swap u-joint.
    IIRC the Pontiac has a larger cross trunion than the Chevy. Quite possibly the drive shaft will need to be shortened also.
    My 65 Chevelle drag car had an Olds/Pontiac rearend but this was in the early 70's so the details are a little fuzzy.
