Rear end mounting options
Discussion in 'The Hokey Ass Message Board' started by mikey502, Nov 23, 2009.
  1. mikey502
    mikey502
    I've been reading over the how to build a traditional ford hot rod book as sort of a guide as well as the forums. I'm not going to be using a banjo rear end nor do I have the radius rods used in the book. What I want to do is mount my rear end using the A rear spring. I know you attach spring hangers (is there another term or is this pretty much a standard one?). but where is the spot to do it? On top, in front or behind the axle? What other options are there besides radius rods yet still considered "traditional"?
  2. hvychvy
    hvychvy
    There are several builds on here.Try looking up in the tech section.There are several builds,maybe you can find one that suites you.I could have not built my model a ,if not for the HAMB.
