Rear end Question
Discussion in 'The Hokey Ass Message Board' started by 59bug, Apr 2, 2010.
  1. 59bug
    59bug
    from missouri
    I've got a 50 chevy deluxe and I want to make her have a better cruising speed on the highway. Can I just swap out the gears in the rear end with higher ones from something. I also want to be able to keep my 3 on the tree. It all original at the moment and only runs about 55.
  2. dgc15
    dgc15
    These have the enclosed torque tube drive line. You could swap for a rear end out of a powerglide car and get a better ratio. Otherwise, your pretty much out of luck unless you change to an open drive line. Then you will have to change transmissions too.
  3. RDR
    RDR
    55 MPH is about were they run with 4.11 like 'dgc15' said, a powerglide drop in/torq tube ***y will fit in there and give you a better hwy gear...also taller tires,instead of 670-15 go up to 760-15 or 225R 15 or 235R15 in rear...bit harder on the clutch tho'...I ran 820-15 on high school car with the 411-3spd...gained about 10 MPH diff with tire change
  4. Snarl
    Snarl
    50-54 cars with powerglides had 3:55 gears. This is the only "easy" option. You will get about another 10 mph.
    Note that when changing gearing or tire size that the speedo is going to read incorrectly.
  5. BuiltFerComfort
    BuiltFerComfort
    Are there 16" wheels that would fit? Mopar went from 16 to 15" wheels about that year, so both sizes will fit, not sure about Chevy. A bigger wheel would work similar to a taller rear end ratio.
  6. Snarl
    Snarl
    starting in '49, the cars were the standard Chevy 5 on 4 3/4" pattern. Only 16" rims with that pattern that would fit would all be aftermarket, as far as I know.
    There are websites with gear calculators that can help you determine what your rpm would be when changing gearing, etc...
  7. 59bug
    59bug
    from missouri
    What gear ratio do you think I have now.
  8. R Pope
    R Pope
    A '50 with a standard trans will have 4.11's. 3.55 P'glide center section and driveshaft bolts right in. Makes a world of difference. Where you go 35 mph now, you'll go 41, so 55 now will be about 62 or so. The speedo will be wrong, though, it'll still be reading 55. There are little gearboxes that go on the trans, before the cable, that might have the right speed increase. S10 4X4's have them, maybe others do too.
  9. 59bug
    59bug
    from missouri
    How hard is a 50-53 powerglide rear end to find?
  10. R Pope
    R Pope
    Shouldn't be too hard to find, about half the cars had them. Talk to anybody that's rodded them, the closed drive is usually the first thing to go. With luck, someone still has the old stuff sitting around.
  11. Pontius
    Pontius
    I have a powerglide rear that I just pulled from my 51 hardtop, that I'd be willing to part with.
