Rear End Question
Discussion in 'The Hokey Ass Message Board' started by Kirk Wilmes, Mar 30, 2012.
  1. Kirk Wilmes
    Kirk Wilmes
    from Altus, OK
    Can anyone tell me what rear housing this is? Took it out of my 50 Merc.
    End to end measures 57"
    Has a 10 bolt backing plate on it
    Center perch to tube end is 5 5/8"
    There are four sets of number cast on them around the cover
    bottom driver side corner- US PAT 2018188
    Top driver side corner0 1968818
    top p***enger corner 18419
    bottom p***enger corner 44
    Would like to put about a 3.55 for highway driving in it since I don't have an OD trans.
    Also, Where can I find a ring and pinion for this thing?
    Thanks.
  2. 38Chevy454
    38Chevy454
    Dana 44 pretty sure. The D44 was used in a lot of vehicles for many years in various configurations. Studebaker, Jeeps, GM/Ford 1/2 ton 4wd front diffs, as some examples. The Jaguar IRS is very close to a D44, and the newer 84-up Corvettes used D44 center sections.
  3. squirrel
    it says 44 right on it, so it's a Dana 44
  4. Retro Jim
    Retro Jim
    Ford used Dana rears for many years . Good strong rear . They are very close looking to a Ford 8" but will not interchange . They used that rear up to 56 then went with a 9" rear in 1957 . The Dana rear will be like a 3.25 ratio . If you get a rear from a 1965 to 1967 Ford Mustang they are pretty much a shoe fit . The housing should be 50" to 52" to fit under the Fords from 1949 to the later 50's .
    Retro Jim
  5. Imperial Kustom
    Imperial Kustom
    Parts for the Dana/****er 44 can be had everywhere from any drivetrain supplier. Start with Randy's Ring and Pinion. Good parts, good prices and great tech guys. Ask for Darren. He knows his **** over there.
