Hot Rods Rear end/ trans / quick change ratio help
Discussion in 'The Hokey Ass Message Board' started by chambies, Jul 24, 2016.
  1. chambies
    chambies
    from ca
    Hello fellow HAMBers
    I am collecting parts for a new project.
    Trying to learn about figuring rear end ratio and final drive.
    I did a little research and read that for a street rod application a final drive ratio <10 is ideal.
    Here is the parts I have so far:
    T5 trans with following gears 1st 3.97, 2.34, 1.48, 1.00, 0.79
    Rear axle is a Ford banjo I have 3:78 and 4:11 gears... but thinking the 3:78 would be best.
    I have no gears for the quick change yet.
    Car will be lighter under 2500lbs, 302 Ford motor with around 300 HP
    I am thinking about running 7.50 tall tires in the rear. So how do I figure this all out? I have read some pages about finding final drive by multiplying the trans gear by the rear.
    For 1st gear this would be 3.97x3.78=15 which is well above that ideal 10 or less. Is this too low for a street rod application?
    Also where is a good starting point for quick change gears.
    Thanks in advance!
  2. Jalopy Joker
    Jalopy Joker
  3. squirrel
    Does that "less than 10" thing apply to 5 speed transmissions? or is it more for older 3 or 4 speeds?
    Did you think about shopping around for a closer ratio transmission? sounds like you have a trans that was meant for a small engine car, if you get one from a higher perf car it will have closer ratios 1-4 and a taller overdrive.
    http://www.allfordmustangs.com/Detailed/349.shtml
    3.78 does sound like a good starting ratio. you can play with the quick change if you don't like it. Don't worry about it, just build it and later on buy a few gear sets to play with.
  4. RichFox
    RichFox
    Yeah. Just start with a set #1. 24 teeth on both change gears.Or #3 and have a 4.11 or 3.48. Should be good.
