Technical Rear End Width -tucked look
Discussion in 'Traditional Hot Rods' started by Steve009, Nov 4, 2024.
  1. Steve009
    Steve009
    from Ottawa
    Hi Everyone,
    first time building a hotrod here so have some patience :)
    trying to figure out what rear end width would give me the look i am after and im hoping some of you have some advice and/or photos to share. building a 32 ford highboy-style roadster. using a quickchange in the rear (not sure of brand yet, Winters, Pacific, etc.). running 1935 16" wires and 7.50-16s tires. I am going after the look of the tires being as tucked into the body wheel arch as possible without rubbing of course. im not a fan when the axles/wheels stick out far past the body. what are your suggested widths for a rear end and do we measure flange to flange, back of drum to back of drum, front of drum to front of drum?
    thanks for the input in advance.
    -Steve
  2. Pete Eastwood
    Pete Eastwood
    from california
    Stand your wheels up next to your body the way you like to see them, then measure in between the wheels and you'll have you're number.
    Can't miss !
  3. alchemy
    alchemy
    Be aware the ‘35 wires will require a brake drum like a 40-48 to fit. Or else will need a thick adapter/spacer.
    After you do as Pete says, send the number to @krylon32 and he can order up the exact ***embly from Winters and Boling Brothers that will give you a perfect fit.
    Steve009 and alanp561 like this.
  4. krylon32
    krylon32
    from Nebraska
    Check my black Henry bodied 32 highboy roadster for sale in the HAMB cl***ifieds. That's a 56 outside width Winter's rear with 16X5 steelies with a neutral off set and 750/R16 Excelsiors. You may want them tucked tighter but the 56 inch rear is what was I used in most of the customer ch***is I did over the last 40+ years. I just finished another deuce ch***is with early Ford wires and Boling Bro's Lincoln brakes. Only requires the thin steel wire wheel support plates for the wires to work correctly.
  5. Tim
    Tim
    from KCMO
  6. Steve009
    Steve009
    from Ottawa
    NealinCA likes this.
  7. Steve009
    Steve009
    from Ottawa
    i think this is the best plan to order the entire unit including the drums as one ***embly. at least the best idea for me since im new to this.
  8. 29Sleeper
    29Sleeper
    from SoCal
    Plan on running a panhard bar or watts link to keep the rearend centered.
    twenty8 likes this.
  9. Steve009
    Steve009
    from Ottawa
    was going to run radius rods mounted to a some sort of centre cross member support and also a torque bar connecting the diff to the centre cross member as well. Not sure what a watts link is.
  10. twenty8
    twenty8
    What @29Sleeper is trying to tell you is that with the wheels/tires tucked in, you will need to make sure you keep any lateral movement of the rear end ***embly to a minimum or you will have a clearance/rubbing issue.
  11. Steve009
    Steve009
    from Ottawa
    oh I see what you mean. Ya I’ll have to give that some thought.
  12. Sforzato
    Sforzato
    Give the guys at Moser a call - they have a huge database of vehicles, rears and brakes to get the axle lengths exactly right. Then again, those guys are probably on this board :)
    Steve009 likes this.
  13. Ned Ludd
    Ned Ludd
    Panhard rod, Watt's linkage, WOBlink, Mumford link, Satchell link, triangulated 4-link: this stuff is fascinating to a certain sort of brain.
    Most of these place the roll centre at around hub height. Triangulated 4-link suspension often has the roll centre slightly above hub height. WOBlinks and Mumford links are usually set up to place the roll centre as low as possible (you might not want to go down the rabbit-hole of learning why you'd want to do that.) The lower the roll centre, the closer the top of the outside tyre is going to come to the body for any given angle of roll. It's easiest to set roll motion out in a diagram, on paper or CAD if you've got. A good roll angle to work to is 6°. Most hot rod ch***is won't allow even that much roll.
  14. Steve009
    Steve009
    from Ottawa
    ...and im officially lost... I better do some reading
    Ned Ludd likes this.
  15. alchemy
    alchemy
    I wouldn’t trust the look of my hot rod to some guys that can’t lay hands on it and measure. There is no better way to get exactly the right look than to do what Pete Eastwood said. Roll the exact wheels and tires in place, then measure in between.
  16. DDDenny
    There is an upside to NOT doing this in that you get to have a selection of wheels for the next project.
    05snopro440 likes this.
