Want To Change The Rear End In My 36 Ford Sedan..350 With 7004 R.any Good Road Gears For This Combo? I Plan To Change Complete Unit.there Is A 86 Mazda Truck Rear In It Now 390.1
Since you have an OD transmission already, anything with a higher ratio will lower the crusing rpm. Try a 3.73:1 or 3.5:1 you will still have good acceleration for a dead stop and highway engine speeds will be low.
Here is a site that will give you a little more information. http://50chevy.freeservers.com/Suspension_Widths.html#Suspension Good Luck
check out toyota trucks (2wd) they are narrow have ford 5 on 4.5 bolt pattern also. they are cheap and stout, they actually have larger diameter axles than a 9". i had a 75' toyota truck with 302/c-4 and tried in vain to blow up the rearend and failed.they also have dropout 3rd member similar to a ford.
Most knowledgeable Hot Rodders measure a rear end width this way ( shown above ) Using the backing plate to backing plate method leaves too much room for errors. Brake drums will vary in width from 1 and 1/2 inches to 3 inches ( different models and different makes ) . That makes room for a error of 2 to 3 inches when using the backing plate method. ALSO ... most of the on-line rear end widths site use the wheel mounting flange method. IMHO ... the perfect rear end for a 35 to 40 Ford is the 57 to 59 Ford 9 inch series rear end. Gear ratios are available from 2.47 to 6.50. 3.25 3.50 3.56 3.70 _______ ALL are fairly common and easy to find .. The 9 inch Ford has the BEST parts supply ... available. Gaskets, bearings, seals ... along with millions of Ford donor cars Here are a few on-line site with rear end widths ... most rodders go for a rear end in the 58 inch range for a 1936 Ford ... http://carnut.com/specs/rear.html http://www.quickperformance.com/Technical%20Info/sus_measure.htm http://www.maliburacing.com/ford_9_inch/ford_nine_inch.htm .... way down on the page ... http://www.mustangsandmore.com/ubb/FordRearDimensions.html
Toyota 2wd, generally 3.73's...... these are narrower than ANY 9", just as strong as a stock 9"...cheaper (usually free) and EASY to get parts for and work on...... Later model 'Yotas...mid 80's and up are a little wider than the earlier ones, @ 2" or so......
I have a ford 8 inch in my A It came out of a maverick. some of the 6 's and the V 8 's came with 5 bolt wheels
Toyota????? Not in My american tin..... Just got a rear dif from a 93 Lincoln Mark VII , 8.8" , 3.55 posi, with disc brakes. 5 on 4 1/2 wheel pattern. Picked the whole car up with running 5.0 HO for $300. Should make a great donor car.
