rear end
Discussion in 'The Hokey Ass Message Board' started by 47fordnut, Oct 12, 2011.
  1. 47fordnut
    47fordnut
    from Iowa
    Help!!! I have a 1947 ford I am pitting a 351w with C6 ****** and was wondering if anyone out there had an idea on a possible rear end match...?
  2. millersgarage
    millersgarage
    What suspension changes have you made?
    I put a 9" Ford in mine, after the Ch***is Engineering leaf spring package.
  3. I used a Ford 8" from a Granada, with the Ch***is Engineering leaf and sway bar kit. Use 7" wide wheels, no clearance issues(can't remember backspacing but not drastic either way)
  4. fordor41
    fordor41
    I have a 1970 Torino 9" with 235/75R15's. Fits into the wheelwells good. B/S about 3"
  5. derbydad276
    derbydad276
    8.8 rear ends are strond,plentiful and cheap and being used in alot of different cars & trucks
    you prolly can find one that will be the exact width you need with disc brakes
  6. FrozenMerc
    FrozenMerc
    All good suggestions.
    I have a Dana 44 in my '51 behind the 351W and 5 spd. Different, but it is strong and reliable.
  7. slepe67
    slepe67
    Mine came out of a '98 expedition. 4.11:1 gears, limited slip, 31 spline axles, aluminum drivshaft=$115 total.
    Sent from my iPhone using TJJ
  8. fordor41
    fordor41
    Just be carefull because a lot of the older rear brake disc parts have been discontinued by Ford. Also 8,8 units have less rolling resistance than the old 8" & 9" units.
  9. RAY With
    RAY With
    I installed a 9 in my 46 and it was out of a 69 galaxie and no problems
