Hey fellows is there a tag are plate on a Maverick to tell me the ratio of the rear end? Where would it be located ? Looking to put it under my 40 ford.. Any help , as to width and difficulty of installation would be appreciated....Will also install leaf springs , difficult??? thanks Cajun dixie
There would be a tag in the studs that hold the pumpkin in. Sometimes they are rusted away or so pitted they are unreadable. They are generally all mid 2 to low 3 ratios. The width is either 55 or 56 inches, a Granada rear is slightly wider and seems to be more suited for a 40. We've used the Ch***is engineering rear spring kits.
I agree.......likely a 2.79 or 3.00 ratio. But, more importantly, may be a bit too narrow. Granada is about 58 1/2". Maverick rear ends are in demand though....perfect fit for Shoebox Fords.
You don't need a TAG or ANYTHING to find a rear end ratio from ANY car ....... open end ( NON posi ).... hold one wheel still...turn other wheel TWO complete revolutions and count the turns of the yoke .... THAT is the ratio posi rear .... turn one tire ( DON'T try to hold the other ) .. ONE complete revolution ... count yoke turns ... THAT IS the ratio ....... ..... Skip
Actually the Maverick at 56.5 " is the perfect rear end for a 35-40 Ford. It's exactly the width that TCI use in all their new 35-40 ch***is. And yes, the ratio will be 2.79 or 3.00
Maverick measures 56.50 The Granada is 58.00 as is the Falcon Just a heads up the Early Bronco's are 58.00 and have the same bolt pattern as the 40 Ford. HRP
My mistake....sorry! The post said it is a '40 Ford and my brain thought '47/'48 in which I installed an 8" and I was remembering that. A slice of humble pie for me!
58" is the magic number, as far as I'm concerned. The spring pads should be the right spacing. I used a 58" wide 8", with 235/70/15 rubber on 7x15 American TTO's, with the standard 3.75" backspace. Anything narrower, and you have to have a shallower backspace.
i remember my cousins husband and his buddy bought a pair of 70 grabber mavericks new,both identical cars and the one car always beat the other. come to find out cousin had dealer install some 3:55 gears and keep it quite. big improvement!
I tried to put a Maverick in my 40 coupe. It fit but was a little too narrow for the ch***is engineering sway bar. It hit the insides of the tires. I found the Granada was just right and still had plenty of room for 15x8 rims. The last two 40 pickups I built, I did use the Maverick in them. I used the Chevy pickup front springs and hangers from a early 50's pickup. . Here is a tech I did on that install. http://www.jalopyjournal.com/forum/showthread.php?t=557363
