Hot Rods Rear Ford banjo hub exchange
Discussion in 'The Hokey Ass Message Board' started by snowroutes, Jul 2, 2016.
  1. snowroutes
    snowroutes
    Is there a way to take the hubs that are 5 on 5 1/2 and get new hubs that are 5 on 4 1/2 and then be able to convert that to disc brakes? Thanks for your help
  2. Texas Webb
    Texas Webb
    Maybe pm rotten leonard for his hub drill jig?
  3. snowroutes
    snowroutes
    Yeah I thought about getting them drilled but then my other question would be is there a way to add disc brakes to it
  4. Mr48chev
    Since the drum comes off the hub
    I'd think it is a fairly simple machine shop operation to change the bolt pattern IF the hub will take a 5 on 4-1/2 bolt pattern with out the back side of the hub interfering with bolt placement. Pretty simple to put a caliper on the back side of the hub and see if there is room for the bolts or if you back up and kick.
    A rotor shouldn't be hard to find but you will either have to machine the hub or rotor to fit the other piece or have a spacer ring machined to match the rotor to the hub.
  5. RICH B
    RICH B
    Not sure what the back side of the repops above look like; but I don't believe rotten leonard's tool would work on a stock Ford hub. The 4-1/2" pattern would get too tight into the hub; probably take some time on a mill to get it to work.
    Another thing to consider is that the outside flange hubs would give you a couple more options
    for rotor spacing; of course they would still have the same deal on the 4-1/2" pattern.
  6. snowroutes
    snowroutes
    Right on guys thanks. A few points I never thought of.
