Technical Rear leaf behind axle question..
Discussion in 'The Hokey Ass Message Board' started by twenty8tudor, Dec 30, 2014.
  1. twenty8tudor
    twenty8tudor
    from Ohio
    I have a front spring out behind the axle on my rpu... It's an original spring from around 42-48... It's 38" eye to eye and I have the mounts at 42.5 due to reading a post from Brian Bass..
    I don't know if the spring is weak/worn out but it's sitting to low which could be remedied with a spacer and moving the rear crossmember.. But the shackles are to far down..
    Going to a spring shop tomorrow but thought I would gather more info before I went..
    Here is where it sits as of now.. Taking the spring out tonight.. But thinking if I narrow the spring by about 1.5" that would get the shackles back up where they need to be..
    One question is if I narrow it and don't put more arch in it the truck will sit lower if I am thinking correctly.. But I don't believe I would need and 1.5" more arch though
    Thoughts.....
  2. krylon32
    krylon32
    from Nebraska
    In the picture your shackles are just about at the right angle under a load. I like to have them at about a 45 degree angle which helps control side sway. Are you satisfied with the ride? I might be inclined to add a spacer to raise the car or just have the spring re arched and not shortened.
  3. twenty8tudor
    twenty8tudor
    from Ohio
    The ride seems to be a little soft and I'll have to check the angle of them when I get home.. I know I put the main leaf in Then the rest of them on. When I do it that way I don't have to stretch it at all it's almost a little long..
    I might cut the one leaf (one above the main leaf) that I currently have out and reinstall it.
    And your adapter worked pretty well for the T-5 thanks again!
  4. Andy
    Andy
    Shortening the spring will make it a little stiffer and so would raise the car a little. The shackles will angle out to the insde some more so that will raise the car some more.
  5. Model A Gomez
    Model A Gomez
    Shackles look about right to me, I have put a spacer on several springs on Model A's, not a problem just a steel plate with an alignment hole and pin. Tire clearance looks about like what I have on my Sport Coupe, and My avatar had about the same clearance.
  6. twenty8tudor
    twenty8tudor
    from Ohio
    The shackles are at about 20 degrees here is a shot of where they are at
  7. twenty8tudor
    twenty8tudor
    from Ohio
    Bump got morning thoughts
  8. timwhit
    timwhit
    The tire/fender relationship really looks good to me. I went through this with my cabrio. To soft, to low. I Added a short leaf which helped maintain some of the arch plus raise the car up. I did add a spacer at the same time.
  9. scrap metal 48
    scrap metal 48
    I would drive it a little and see if it changes angles.. If it doesn't I would drive and enjoy it like it is...
  10. jseery
    jseery
    from Wichita KS
    Needs to be closer to 45 degrees. You can have the spring shortened (just had one done for $20) or have the arch in the spring increased (or do it yourself), or add a leaf or two.
