Hot Rods Rear leaf springs
Discussion in 'The Hokey Ass Message Board' started by moparjack44, Feb 28, 2017.
  1. moparjack44
    moparjack44
    The rear end of my car is 70 Plymouth with leaf springs. I replaced them a couple of years ago with new ones. It rides a little stiff for my liking, so I am considering removing a couple of the leafs. Which leafs would you recommend that I remove? I want little softer ride, but not lower the rear much..
    Jackie
  2. Jalopy Joker
    Jalopy Joker
    post pics of what you have to work with - just removing leafs may not be the only answer
  3. moparjack44
    moparjack44
    As soon as I can get my daughter to take pictures, I will, and have her post. It's 4 leafs with air bags on the rear only. Not a four link, just bags mounted on top of leaf springs and a bracket.
  4. moparjack44
    moparjack44
    No pictures yet. It's your basic leaf spring set up. If has 4 leafs going under the axle, on stock spring hangers? I do have 1" lowering blocks and air bags only on the rear. I reckon I can just experiment to see what happens, just hate to, takes a little time, and have to do it on the garage floor. Don't have a lift, and I'm lazy and old?
  5. Joe H
    Joe H
    Why do you have air bags and leaf springs? Try just normal shocks and see how it rides.
  6. moparjack44
    moparjack44
    Yeah, I know?
    I drive this old car any where and everywhere. When I drive it on vacation loaded with luggage, plus my cooler, and my faithful 105 lb Golden Retriever, had a problem bottoming out. I just pumped up the air bags to eliminate that, and it works.
