Rear licence plate mounts
Discussion in 'The Hokey Ass Message Board' started by 66nova383, May 3, 2013.
  1. 66nova383
    66nova383
    I am looking for pictures and ideas of how you mounted your rear licence plate.My Austin dosn't have bumpers so I will have to mount it underneath on the rear cross member.I will not put holes in the body.
      230.9 KB
      323.4 KB
      283.2 KB
  2. 343w
    343w
    Center it on the rear pan, make the mounting point at the rear crossmember under the body. One of the old school type with the light on top would work, paint it green like the machine...
  3. 1971BB427
    1971BB427
    from Oregon
    Get a solenoid and build a hinged mount under the rear pan. Then just put a switch on it to activate the solenoid and pivot the plate down when driving. Then you can have it clean, and no plate when you're parked or off the street.
    BTW-The Austin looks fantastic!
  4. 66nova383
    66nova383
    Kind of what I have in mind have not seen anything that I really like. Thanks
  5. 66nova383
    66nova383
    Thanks 1971bb427,I thought about the fold ups but she sits really low and might not clear the ground.
  6. 66nova383
    66nova383
    Some where I saw a manual slide out flip up mount, but of course now I can't find it on the net.
  7. 5window
    5window
    Better check with your state DMV-sometimes there are height requirements.
  8. DS1937
    DS1937
    If you set it up with a solenoid, be sure to use a continuous duty one since it will have to stay energized to keep the plate down.
