1952-59 Ford Rear lowering blocks
Discussion in 'Off Topic Hot Rods & Customs' started by Ian hall, Aug 30, 2014.
  1. Ian hall
    Ian hall
    from Uk
    Going to fit the Aerostar springs to the front of the 53.
    Looking at blocks for the rear, can get 3" ones here. If they are too low I could machine that to 2"
    Thing is they are for a 3" axle tube, I make my axle a little less than that, will they be ok or is there a better kit available?
    Ian
  2. Dobie Gillis
    Dobie Gillis
    Yours are 2" wide. I had the same problem on my Merc. I got a pair of billet aluminum blocks from Speedway that were 3" wide and machined them down to 2" wide. The hole for the locator pin is too big so you'll need to shim your pin to size. The cylinder head alignment dowels for a Nissan engine work very well for this since they are hollow and a snap fit over the alignment pins and snap into the holes in the blocks. You may find 3" a bit much: mine are 2" and I still have to sneak up on some railroad crossings, driveway entrances, etc.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. Ian hall
    Ian hall
    from Uk
    I can get 2" wide blocks to suit the springs,it is the axle tube diameter I wanted to check. The u bolts i can get are 3" inside and the axle is just over 2 and 3/4" will these pull up ok or will I need some kind of packer or shim of some kind or a different u bolt
    Ian
  5. Ian hall
    Ian hall
    from Uk
    Looks like I will have to go either butchscoolstuff or shoebox Central, having no luck over here(uk)
    Ian
  6. Ian hall
    Ian hall
    from Uk
    Got some 2" wide blocks with a 3" drop. Had them machined down to a 2" drop but now find that I need to have a sleeve to locate block to axle and the hole that locates to the spring is way too small! More machining!!
    Ian
  7. bobss396
    bobss396
    The machining is the easy part. I would like to drop mine in the rear, have to see how it sits with it all ***embled first.
  8. EchoOfGecko
    EchoOfGecko
    Are you guys using the rubber pads and plates on top and bottom of the block/spring pack? This should take up the difference between the smaller pins on the top of the block and bottom of the springs, and the larger holes on the rear end and the lower plate.
    2ea per side, top and bottom
    B9SZ-5741-A
    B2AZ-5736-A
  9. Ian hall
    Ian hall
    from Uk
    I'm having a load of h***le getting the aluminium blocks machined to fit, would have been easier to make blocks out of 2"x2" box section with plates welded on the ends!
    Ian
  10. Dobie Gillis
    Dobie Gillis
    Nope, didn't know such things existed. The blocks I got from Speedway are for Scrub pickups. I have access to a good machinist so I had him cut 'em down to size. The PO had some in there that were too wide and they would not stay put no matter what I did. The new ones are a perfect fit and should outlast me since they're solid.
  11. Custom_Crestline
    Custom_Crestline
    Are you running dropped springs? 3 inch blocks shouldn't rub a driveshaft tunnel at all. I've had 4 inch blocks in my car, with aged springs, and that causes some problems when it comes to a full trunk and p***engers, but 3 should have been fine.
  12. Ian hall
    Ian hall
    from Uk
    2" drop should have my car sitting level with the ground, I suppose the aerostars might settle a little which will give a slight rake. Hope to have the blocks fitted soon
    Ian
  13. Ian hall
    Ian hall
    from Uk
    Ended up making my own blocks from 2"x2" square section
