rear mounted radiator
Discussion in 'The Hokey Ass Message Board' started by Motorbreath, May 12, 2007.
  1. 29bowtie
    29bowtie
    LOL ,We need a HAMB translation editor!!!:rolleyes:for some of the US Hambers,at least us Canadians still have enough English influence to understand the Aussies.;)
  2. Motorbreath
    Motorbreath
    29bowtie it definetly threw me till he explained... ha ha
  3. Flatty
    Flatty
    did you ever do this? I am tossing the idea arounda s well. I have done this in a rockcrawler, but never in a car I drive on the street.
    Dima
  4. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Littleman has done this in his A and it works fine
    Bob Walker has done this as well in his 34 coupe and it works,.
    very interesting.
  5. DrJ
    DrJ
    Lacking use of a wind tunnel, I'd put a few box fans on high speed in front of the mocked up truck and hold a streamer (piece of light ribbon) on a stick and move it around above and under the bed to find out exactly what the wind/airflow wants to do on it's own, then modify with scoops if necessaryto get it to go your way.
    A scoop under neath could be used either to **** air in or turned rearwards to **** it out.
    where do leaves/****s/jerkey wrappers go in the open bed of a truck?
    Up near the cab?
    You may find the air wants to go through your radiator the opposite way you think it would, or even reverse at different speeds.
  6. Motorbreath
    Motorbreath
    Flatty i got it in there, havent ran it yet, check my signature for a link to the whole truck...
  7. my son wants to make his radiator part of the tailgate...i.e. make an outer frame and put a crossflow radiator in the middle of the gate with 2 fans inside on the gate. He wont have a floor in the bed. should the fans be pull or push style?:confused:
  8. porkchop4464
    porkchop4464
    I would think pull from ground and out gate, seems like road travel air would come up the bottom of frame and out gate. I am thinking of doing mine similar(out the gate) so that it is easy to access and work on. I have yet to see any type of screen or grill that looks great on a rear mount system.
  9. k9racer
    k9racer
    If you are using a thermostat no need to have tubing over 1 inch to flow water to the radiator. This means the flow is restricted to around 3/4 inch any way. I tried this on a circle track racer. I never had the time to work out the bugs as the rules were clairfied to say radiator must be in front of the engine one rad only... ..
  10. HOTRODPRIMER
    HOTRODPRIMER
    Since this thread has been resurrected from 2007 I would think the rear mounted radiator would not be considered pertinent to today's refocusing of the Hamb. HRP
  11. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    new section made up for this stuff...for hotrodding today
    ...........so it belongs still..........just sayin, Littleman
  12. Roger Walling
    Roger Walling
    I mounted a radiator about 10 ' away from the motor on a car and I went to a hose specialty shop to get a flex hose to connect them.
    I gave them the specs, heat, pressure resistant to antifreeze and size and they came up with a hose that surprised me. Air hose, 1&1/2' dia. 300# working pressure! The price was right too!
    The best part is while it ran through the p***. compartment, I diden't have to insulate it as it was so thick.
  13. GREAZERZ
    GREAZERZ
    from Frisco, TX
    Great info DocWatson - I'm thinking about doing this in a Model A, so the information certainly helps!!!
