rear shock mounting questions
Discussion in 'The Hokey Ass Message Board' started by fordiac, Jun 6, 2004.
  1. fordiac
    fordiac
    from Medina, Oh
    ok guys, 66 ford truck, leaf spring rear.
    should apply to any parralel leaf spring rears...
    when i build shock mounts, do they have to be "in phase"?
    the end of the individual shocks, the attaching bolts, do they have to be parralel, or is it ok to mount them like a "+"
    reason im askin is that i put the axle on top of my springs and c-notched the frame, eliminating the top mount, and the bottom mount was way crooked.
    should i run a square tube across the frame, and mount the top of the shocks to that, or build a mount off the boxing plate?
    bottom one is not too bad, find a 3" hole saw and use some 2x4 tubing i have layin around, and drill some holes in it...
    where can i look up shocks and find one that fits? anyone have a good website or source? do the books at NAPA have good "universal" shock descriptions?
    thanks
  2. fordiac
    fordiac
    from Medina, Oh
    a tech question and only 22 views in 7 hours? wtf?
    BTTT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  3. burger
    burger
    here's a link that curious rash posted last week with a "universal shock table"
    shocking shock table
    ed
  4. mikeyboy
    mikeyboy
    your friendly local Napa shock catalog has the extended/collapsed/mounting info in the back of the book. as for mounting, on the 46 we ran a 1" square tube across the top of the frame, and made mounts out of the same, take about a 2"piece of tube, and cut one end ata a 45 degree, drill the hole in the long side. and you're done
