Projects Rear shock mounting?
Discussion in 'The Hokey Ass Message Board' started by StefanS, Dec 16, 2025.
  1. StefanS
    StefanS
    from Maryland
    What are your guys thoughts on shocks being mounted vertically from the side view and the tops angled in toward the center from the rear view, any issues? How much does the axle move forward or rearward and do poly bushings have enough deflection?
    These are going on my '49 Shoebox with St. Lois Spring 4" (really closer to 5") dropped leaves with 2" blocks and the leaves are just about flat at ride height.
    I'm notching the rear to get the shocks more vertical than the stock frame mounting points will be and also to get some decent shock length.
  2. Rickybop
    Rickybop
    Just don't angle 'em too much.
    At 45° they're only about 1/2 as effective.
    gnichols likes this.
  3. StefanS
    StefanS
    from Maryland
    I'm going to go as close to the leaves with the axle bracket As I can reasonably get them and they just have to angle in far enough at the top to clear my 1.75" pipes With probably an inch so of extra clearance for good measure so I'm thinking they should be right around 20°. My main concern is mounting them vertically from the side view. I know when the leaf spring compresses or droops it's going to move the axle forward a tiny bit since it sits flat at ride height but I'm not sure how much and if the bushings of the shock will deflect enough or causes binding
  4. swade41
    swade41
    from Buffalo,NY
    Look at the factory angle on my 57 Chevy pickup
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    I would turn either the top or bottom 90 degrees so you will not snap off the mounting studs if there is any deflection. Just make two brackets and put a bolt through from the sides
    lostone and GuyW like this.
  6. StefanS
    StefanS
    from Maryland
    Looks pretty much like my picture huh?
    swade41 likes this.
  7. BJR
    BJR
  8. deucemac
    deucemac
    Optimum angle is 7 to 10 degrees maximum the further you deviate from that, the more have a hydraulic sway bar instead of a shock absorber. Learned the hard way in the late 70's when we converted a 40 Ford convertible to tube shocks and didn't listen to an "old" who was 40+. Never made that mistake again!
  9. alchemy
    alchemy
    There are millions of shocks mounted perfectly vertical, and the bushings take up the deviation of the angle as the suspension compresses. But as these guys are telling you, be aware of the reduction in effectiveness as you tilt the upper inward too much.
  10. Bandit Billy
    Bandit Billy
    Dude! I met that cat once. He was **** for a fisherman but a hell of a good angler, man.
  11. StefanS
    StefanS
    from Maryland
    I just Took a rough estimate of how my shock angles will be and it's 20° (or 70 depending on how you want to say it) at the absolute maximum. I can move the axle bracket more towards the center if I really needed to I just don't wanna get too far away from the outer edge of the axle tubes
