Rear shock mounts w/36 bones
Discussion in 'The Hokey Ass Message Board' started by ty johnson, May 27, 2013.
  1. ty johnson
    ty johnson
    Hey guys, i'm wondering if anyone has used the rear portion of the 36 radius rod to mount the shock from. Any pics of them would be great. I know it's probably been done, just looking for info. The spring hanger has been removed and i'd be drilling and adding a shock stud. They are being mounted triangular.
    Thanks,
    Ty
  2. F&J
    F&J
    If you go off the rear part of the forging that goes up higher than the axle tube, you'd want short shocks, I would guess. Depends on what the whole ch***is setup is
    If your are using a 32-up frame with a stock rear crossmember, I don't think there is enough room for a shock to fit up top?
    If you don't have that setup, you could weld the shock studs to the forged end. There are shock studs that come with some Chevy truck replacement shocks, that have a beefy center part that would weld up good, if you cut the unneeded theads off of it. It was made to bolt into the frame, so just cut it off.
  3. tmf
    tmf
    I mounted socal front mounts upside down on the diff. Works well so far.
  4. ty johnson
    ty johnson
    Is that like a F1 style mount?^ I was actually thinking of like F&J was talking. Just looking for more info or pics.
  5. tmf
    tmf
    Yep F1 style upside down.
  6. Dak Rat
    Dak Rat
    from NoDak
    What a neat idea!
  7. ty johnson
    ty johnson
    Looks good and effective.
