Technical Rear Shock Mounts
Discussion in 'Traditional Hot Rods' started by TomDE, May 10, 2019.
  1. TomDE
    TomDE
    Hi,
    I found this picture in my library but I do not know where I got it from.
    Can someone tell me how the lower shock mounts look like on this setup?
    Thanks for any advise
    Tom
  2. AngleDrive
    AngleDrive
    from Florida
    Most likely a tab welded to the radius rod.
  3. Ralph Moore
    Ralph Moore
    Or tab welded to axle, a cut off end of a 37-40 rear radius arm works great
  4. mgtstumpy
    mgtstumpy
  5. TomDE
    TomDE
    mgtstumpy likes this.
  6. F&J
    F&J
    Looks like they had to notch the spring crossmember because it's so tight for space.
    On my 32 with 35/36 arms, I ran the shocks right in front of the axle. The lower mounts are just two short tabs welded to the insides of the bones. The top mount is a fabbed straight crossmember with shock studs welded in.
    Stovebolt likes this.
