Projects Rear side windows chopped top
Discussion in 'Traditional Customs' started by italianhotrodder, May 1, 2018.
  1. italianhotrodder
    italianhotrodder
    from sweden
    DCDF2DDC-DD35-42C9-9CDD-6741AA6BB4A9.jpeg 05B5ED59-FD32-4C2C-96D9-9BBDA1FBD5BF.jpeg hi guys need a suggest how to mount the rear side windows on my chopped top car, the rear windows now is fix windows and i want to give it a bent shape to the rear and front gl*** but there is a gap between rear and front door in a corner in the bottom i would like to mount the gl*** without modify the front door any suggestions ?
  2. BJR
    BJR
    How about a picture of the whole window you want to fix? Not just small pieces of it, so we can see what you are dealing with.
  3. Stonebird
    Stonebird
    I don't have a good solution but, I think what he is saying is he wants the quarter gl*** to seal against the door gl***, but there is a piece of the door in the way at the back of the door. Can't get the door gl*** back far enough. Doesn't want to modify the door.
  4. italianhotrodder
    italianhotrodder
    from sweden
    yes that's the problem, and studing some other guys solutions the 90 % of them use Matranga style windows
  5. italianhotrodder
    italianhotrodder
    from sweden
    i don't have good picture of the whole car here is the car glass.jpg glass2.jpg
  6. RICH B
    RICH B
    See if you can find an original car and get some pictures of the area in question; I think you will find that the quarter window frame is closer to the door gl***, which in turn lets the rubber flap be far enough forward to overlap the rear edge of the door gl***. I've seen on similar car the quarter windows don't go straight up and down; but "rotate" into place and overlap the door gl*** area when up. Should be able to duplicate the same position with a fixed window.
  7. italianhotrodder
    italianhotrodder
    from sweden
    did a small mock up but 90% i decided to build a matranga style windows it's ugly in that way i will try to find a better stainless steel profile
  8. RICH B
    RICH B
    I'm kinda thinking straight may look better than curved on that car.
    I salvaged the leading edges from some '59 Ford hardtop quarter windows to use on my car.
    Fits flat gl*** and there are repop rubber seals available.
  9. atomickustom
    atomickustom
    Sharp car!
    I agree that straight suits that car better, and I think Rich B is correct that the rear gl*** simply has to stick out closer to the door gl***.
    One other point to consider: some cars have the stainless and rubber on the rear gl***, but others have it on the door gl*** so that when the front window is rolled down the rear quarter window is just...gl***. I know it's not HAMB friendly, but I've posted a photo of a 1969 Dodge Charger here because I used to own one and knew it had that arrangement. See how the rear window is up but there is no trim on the front edge? That's how they are made. The stainless and rubber is on the door gl***.
    Maybe that could make it easier to do what you are trying to accomplish?
    Here is a closeup of the front & rear side gl*** with the rear rolled down just a bit:
