Rear spring question /Model A
Discussion in 'The Hokey Ass Message Board' started by choprods, Jun 26, 2004.
  1. Im setting up the rear spring,and made the mount brackets that mount the rear end to the spring.
    I havent welded em on housing yet,
    I am using speedy bills shackle kit,and it will have the'T" shaped affair that is on the opposite end of the shackle- to bolt to this bracket I made .My question is this:
    It said in speedways description that the spring was for 42-1/2" mount spacing....I am****uming that is the distance between the left and right spring eyes-LOADED??????
    Now- how far apart should my two brackets be spaced>
    do I spread the spring with a spreader till the two eyes are that spacing or what is a normal amount of distance between the two [vertical]-rear facing brackets that are welded to bottom of rear axle????
    anyone help me here? [​IMG]THANKS in advance
  2. i'm not sure about the parts you are using , but on a stock model a spring the hanger brackets on the rear end were 48" center to center. a stock model A spring had 38-40" center to center eyes unloaded,depending on how many leafs it had.
    the shackles add 1-3/4" per side , then the spring had to be stretched on to the hanger brackets. you will end up with the shackels at about 45 degree then
    42-1/2 sounds short..is this a model a spring? what is the unloaded length of the spring? what is the speedway part numbar?
