Rear Spring Question-Will this work??
Discussion in 'The Hokey Ass Message Board' started by Spooky, Jan 23, 2004.
  1. Spooky
    Spooky
    Howza Bruthas,
    On my never ending pursuit of jalopysism(c), I am wondering about a rear spring idea I have. See, I have the remains of an old Buick beam axle with some pretty serious looking leafs on them. It is nearly the width of the Model A frame. I am wondering if this spring combined with the shackles it originally came with (which look pretty damned heavy duty as well) will work for the rear of my roadster project?
    See, I am trying to keep from Z'ing the frame, because it would raise my gas tank above the rear of the car. I like the look of the banjo rear and I am still trying to keep to a budget here.
    Any opinions?
    Here is a pic of the spring and shackles...
  2. Spooky
    Spooky
    A shot of the rear area...
  3. Spooky
    Spooky
    Finally, a close up of the Buick spring.
  4. Levis Classic
    Levis Classic
    Does it have enugh arch to clear the banjo? Mock it up and see!
  5. 67Imp.Wagon
    67Imp.Wagon
    You also have to think about if it does clear will the rear end bottom on it when you hit a bump.
  6. Randy D
    Randy D
    and with that many leaves in the pack,it wouldn't have much compression when used as a rear spring. If you mounted it behind the diff like a 35, 36.....ford, it should be fine with some of the leaves taken out. But that would mean moving the crossmember back.
  7. Tim
    Tim
    from KCMO
    mount it in front or suicide it off the bones>? im sure theres some way to make it work for ya
  8. Spooky
    Spooky
    Alright my friends, I am going to mount it up and see what it looks like. I justrealised I took a pic of the spring with the shackles in the WRONG direction.
    D'OH! [​IMG]
