Projects Rear spring toque ?
Discussion in 'The Hokey Ass Message Board' started by mark hogan, Feb 10, 2024.
  1. mark hogan
    mark hogan
    IMG_4547.jpeg Can’t seem to find any info on torquing down rear spring! Any ideas…
  2. seb fontana
    seb fontana
    from ct
    Tight?:rolleyes: 35/40 ft lbs
  3. 73RR
    73RR
    If you are referring to a u-bolt with nut then use the published values for the bolt size. Over torquing can distort threads or even stretch the bolt causing damage.
  4. AngleDrive
    AngleDrive
    from Florida
    65 to 80. Need to retorque after 50 miles of driving
    26 T Ford RPU and chryslerfan55 like this.
  5. '29 Gizmo
    '29 Gizmo
    from UK
    Ford didnt use a torque wrench till the mid 30s.. tight will do
    Dave G in Gansevoort likes this.
  6. krylon32
    krylon32
    from Nebraska
    Done dozens. TIGHT
  7. 19Fordy
    19Fordy
  8. mark hogan
    mark hogan
    Thanks for all the replies I’ve got so many Manuel’s and not one mentions the sequence or tightness ? I’ll turn them down tight. Good day.
  9. Snugged down enough to get the cotter pin inserted. Done.
    '29 Gizmo likes this.
