Technical Rear Springs on 60 BelAir
Discussion in 'Traditional Customs' started by dtwbcs, Sep 15, 2013.
  1. dtwbcs
    dtwbcs
    from Brenham,TX
    I want to put my 1960 BelAir 4dr sedan at STOCK height.The front looks correct.THe back is high.Rear coil spring installed is a moog 661.After installing it looks terrible.What is the correct height coil?Part#?
  2. scoTT la rock
    scoTT la rock
    from NJ
    Might want to ask on chevytalk.com - lots of knowledge there and you'll find your answer quickly
  3. hoop98
    hoop98
    from Texas
    That 661 is 1.8 inches taller than the stock spring 16.84 vs 15.03.
    I'll see if I can find the right spring.
    The best thing to do is cut that spring 1.6 inches from where it is now. Put a yardstick beside it and find the top with the spring vertical. It should be 16.8, cut it 1.6 inches in height with a cut off disk. It will be just a tad softer.
  4. slammed
    slammed
    Is the front spring height correct? It looks lowered. If you trim a 1/2 wrap from each end of the present rear coil will be 1" lower and still ride fine.
  5. 53 COE
    53 COE
    from PNW
  6. dtwbcs
    dtwbcs
    from Brenham,TX
    Good eye ...front spring(658A) might be wrong for the car but it looks ok.At least I like the ride now.Just frustrating that even with all of the knowledge that we have today to cross reference;that I still received the wrong part.Sure,sure it fit....
  7. dtwbcs
    dtwbcs
    from Brenham,TX
    1.81" taller. How do I read that on my measuring tape? It reads in 1/8ths so 1.8 is what?? on tape to mark&cut?
  8. 1955IHC
    1955IHC
    1 13/16"
    Sent via Western Union Express
  9. Clevername
    Clevername
    The back looks fine and the front looks lowered about 3.5. Buy a set of stock springs from Eckler's. It will set you back about $200 for all four.
    Why are you posting this in "Traditional Customs", clearly you are making it a stock car?
    Kelvin
  10. hoop98
    hoop98
    from Texas
    Here are the possible stock springs. If you take 1 inch from the 661 it will be close to the D spring. The B spring is similar height to the 661, but very soft so it compresses a lot.
    Trim the spring 1 inch and see how it looks, should be close. Here are the specs.
  11. hoop98
    hoop98
    from Texas
    I didn't realize it was a 6 cylinder, it would use the D spring.
    Here is a comparison of the stock springs, the 661 and the 661 cut either 1 or 1.5 inches. The compare height is an imaginary ride height measurement. It shows the effect of each spring on ride height with the same load. I used 1075 as the weight on each rear which would me somewhat loaded, say 4 passengers.
  12. hoop98
    hoop98
    from Texas
    Adding the front;
  13. dtwbcs
    dtwbcs
    from Brenham,TX
    So I would just be cutting off an inch...I can do that
  14. hoop98
    hoop98
    from Texas
    Yes an inch in height, stand up a yardstick next to the spring, this is an example, I don't think you have square ends so the spring won't stand up easily. You will need to support it.
  15. dtwbcs
    dtwbcs
    from Brenham,TX
    Hoop,
    U say 1" but 16.84minus15.03 is 1.81 which is about 1 13/16" ;which is one mark past 1 3/4"--so what would 2"look like?
  16. dtwbcs
    dtwbcs
    from Brenham,TX
    Guess I could start by cutting 1" then sticking coils back in place then lower the car...that calculation earlier seems closer to what I might be aiming for(1 13/16")-->
    LEVEL <---
    But how do I get there from where it sits.....:confused:.
    startin to think "there is some trial&error" gittin ready to happen
  17. dtwbcs
    dtwbcs
    from Brenham,TX
    now where is that cutoff wheel hiding....
  18. hoop98
    hoop98
    from Texas
    I would try one inch first :)
  19. dtwbcs
    dtwbcs
    from Brenham,TX
    I agree;can always cutoff more But cant put back:eek:
  20. dtwbcs
    dtwbcs
    from Brenham,TX
    Just want 2 THANK all who have given me advice:cool:
  21. Clevername
    Clevername
    The chevy springs are not flat on either end. I just replaced mine on all four corners. I am about 95% sure there is a seat where the end of the spring goes on the rear springs -I am positive about this on the front. What I am getting at is, you will want to take one turn of the spring out if possible -this will be pretty close to 1 in.
    Kelvin
  22. Clevername
    Clevername
    I still think your car looks low in the front, I just measured mine. It is 24in from the floor to the bottom of the wheel opening, and I have 2in dropped spindles and 1.5in shorter springs.
    Kelvin
  23. slammed
    slammed
    In the rear there is a pocket/recess top and bottom for the spring end to seat. Take a half a wrap from both ends and you shall receive a 1"+ drop. A FULL wrap of coil removed will drop it around 2".
  24. hoop98
    hoop98
    from Texas
    The springs are tangential on both ends,
    A one inch cut will drop the car about 1.4 inches because of the spring motion ratio.
  25. 5559
    5559
    from tn
    start by cutting one coil & see if its better
  26. hoop98
    hoop98
    from Texas
    Since there are ten coils total that would be 1.6 inch per coil. So 2/3 coil would be closer to one inch.
  27. dtwbcs
    dtwbcs
    from Brenham,TX
    Ok,here is what I got.cut 1 coils' worth
    Think maybe half a coil more...
  28. hoop98
    hoop98
    from Texas
    go drive it to be sure the spring settles
  29. slammed
    slammed
    Park on a level surface. Measure the fender to ground on all 4 corners, write it down. And get UP on that car for the pix, your stalker distance is killing the look.
