Technical Rear Suspension question
Discussion in 'Traditional Hot Rods' started by Boon BA, Jul 29, 2015.
  1. Boon BA
    Boon BA
    1930 Model A (7).jpg If I have Deuce rails, Buggy Spring and split bones mounted on a cross member, Do I need a pan hard bar on my Banjo rear end?
  2. Loaded question.
    With short shackles and no wag in them - you don't need one, but its not going to hurt to have it.
    If I only had room for one, Id rather have an anti roll bar.
  3. Mike VV
    Mike VV
    from SoCal
    What 31Vicky said. The the Panhard rod the anti-sway bar do two different things.
    Just for the accuracy of it, Panhard is one word, the guys name who came up with the idea.
    Mike
  4. HOTRODPRIMER
    HOTRODPRIMER
    Open drive,I would use one.
    BTW, The ch***is looks great . HRP
  5. Kerrynzl
    Kerrynzl
    put longer shackles in it so they are more vertical, then use a panhard.
    The shackles can "float" enough to eliminate any binding with the panhard.
  6. With open drive what you really need is a torque arm. You have done more then one thing when you split the bones and took away the closed drive shaft (torque tube), you have lost a little triangulation and you have loaded a lot of the stress that the torque tube used to take up on the bones.
  7. ct1932ford
    ct1932ford
    What are you building? Like the green. The guys above have it right.
  8. pitman
    pitman
    Tall closed cars tend to roll more than the open versions.
  9. krylon32
    krylon32
    from Nebraska
    Have built 100's of buggy spring rear suspensions with ladder bars and to date have never used a panard bar. I always design the suspension so the shackles are at a 45 degree angle under a load. I have had no customer complaints yet. All three of my current deuces, (3 window, delivery and roadster) have buggy spring rear suspension. I do agree with the need for a torque arm since you are using the early bones.
    AHotRod likes this.
  10. Boon BA
    Boon BA
    "What are you building? Like the green. The guys above have it right."
    It's a finished car that I just bought. Going through it and want to "fix" anything before I get too far down the road.
    Thanks for the responses. Here's a pic of the car.
    Boon
  11. RB35
    RB35
  12. Yep! Nice one
    Panhard bar keeps the rear centered left and right during suspension travel.
    Torque arm keeps the rear end from rolling under torque load from engine or braking.
    Anti sway bar helps with body roll on buggy springs
  13. dad-bud
    dad-bud
    Boon, your coupe looks great.
    Suggest you listen to those recommending a panhard bar plus torque arm - they're giving good advice.
    Cheers.
  14. Funny no one mentioned watts link. :D
  15. bgaro
    bgaro
    what ****** said. i'm seeing a torque arm being more affective for this set up.
  16. I have actually spent the last hour or so looking for a pic of the Raven launching the '27 @ MOKAN, 5" wide tires (traction impaired) mild 355 and light car. The split bones are a rainbow. we have since gone to ladder bars.
  17. a friend of mine built that car , the only thing i would add if it was mine is a torque arm as suggested ...no need for a rear panhard
  18. 117harv
    117harv
    The car already has a panhard bar, it's also called a spring. As for the torque arm being needed, it depends on what bones and how they are mounted as well as horse power. Since it is a finished driving car I would think all is in order...no?
  19. alchemy
    alchemy
    Do you have a problem of tires scrubbing the body when you are "drifting"? No? Then no need to add the Panhard. As stated above, a shackle at 45 degrees does the job of keeping the axle in the correct position side-to-side.
  20. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    I see no need for a Panhard bar on a buggy sprung car. Period!!!
  21. Boon BA
    Boon BA
    Thanks guys. I'll drive it and decide if any corrections are needed. :)
