Technical Rear tire size help?
Discussion in 'Traditional Hot Rods' started by GCDC, May 4, 2022.
  1. Firestone size
    0 vote(s)
    0.0%
  2. 16 inc rim
    1 vote(s)
    100.0%
  1. GCDC
    GCDC
    Anyone know what size tire is in rear of this car .
    I know the front one is a Firestone 500-5.25/16.
    Or what’s a good rear tire for a 32 coupe with fenders ? 650-670-700? 3D89D1C2-814C-4B44-A426-40A3AB74F8EA.jpeg 00538A9D-E8A2-4DEA-99AD-340A8522D96B.jpeg
  2. hemihotrod66
    hemihotrod66
    What goes around comes around,,,, When I was a young hotrodder everyone wanted 14 or 15 inch tires...Old Chevys were the worst because they were 6 lug...They use to search hard for the 6 lug 15 inch Chevy rim...Now my new pickup has 18 inch back to 1932 I guess...
    Automotive Stud, Bob Lowry and GCDC like this.
  3. Dan Hay
    Dan Hay
    Can't go wrong with a 700 or 750 16 in the rear.
    FlatJan, clem, GCDC and 1 other person like this.
  4. Just Gary
    Just Gary
    clem and Dan Hay like this.
  5. sloppy jalopies
    sloppy jalopies
    the taller the tire the less RPMs the engine has to put out at the same speed...
    what are the travel plans... long trips or round town...
  6. GCDC
    GCDC
    I have a set of Firestone 550-16 fronts and 750 rears
    Was going to run no fenders but decided to keep them on for now . The 750 -16 looks huge .
    Plan on driving it a lot lot short trips . Some freeway driving. .
    sloppy jalopies likes this.
  7. GCDC
    GCDC
    Is there a big difference between a 750-16 vs 700-16?
  8. krylon32
    krylon32
    from Nebraska
    Check Coker's website and go to Firestone tires and they will have the specs for the various sizes.
  9. It depends on how much room you have for the tire. A lot of people shoot for a 7.50 rear tire. BTW those are 16" wheels in the picture (by the distance of the flat area between hubcap and wheel hoop).
  10. Mr48chev
    On Cokers site a 7.50 16 pie crust is 31 inches OD
    700 is 30.4
    670 is 28.62
    GCDC likes this.
  11. GCDC
    GCDC
    I tried calling Coker ,guy on the phone didnt know to much .
  12. Mr48chev
  13. Bob Lowry
    Bob Lowry
    Here is a closer up of the rear tire sidewall...8.00 to 8.25 - 16?
    clem and GCDC like this.
  14. ekimneirbo
    ekimneirbo
    The gap between the edge of the tire and the edge of the fender...........both horizontally and vertically will detrmine a whole lot in wheter your car "looks right". Everyone......not really, but many 32 builders feel this is only right when the gap is reasonably small with a large tire. Here is a picture of a 265/75/15r tire and its fender relation. The tire chart says its 30.6" in diameter and 10.4" wide. If that suits you, you can use the attached chart and look for a similar size in 16" tires.
    https://tiresize.com/chart/
    Ned Ludd and GCDC like this.
  15. jimmy six
    jimmy six
    More importantly what’s the transmission and rear gear you have?
    clem likes this.
  16. GCDC
    GCDC
    39 trans with a 39 rear end . not sure on gears
    jimmy six likes this.
  17. Ned Ludd
    Ned Ludd
    tiresize.com is a good resource. I like the way you can search in 1" overall-diameter ranges.
    For those who are interested, the way to decipher metric tyre sizes, taking that example:
    (265 x 0.75 x 2)/25.4 + 15 = 30.65" nominal diameter
    265/25.4 = 10.43" nominal section width
    Actual tyres are the size they are. The designations are rounded to the nearest 5mm width and 5% aspect ratio.
    ekimneirbo, jim32 and Just Gary like this.
  18. Bob Lowry
    Bob Lowry
    Here is a pretty cool link, it will tell you actual tire height based on tire size, so
    you can measure how tall a tire would be for your car. It has worked well for
    me in the past...
    Tire Height Calculator (tiresize.com)
  19. continentaljohn
    continentaljohn
    I run 7:50 x16 in the rear on everything and front depending on fenders and era of car. I have a set of 8:20x16 but are too tall 2643411C-A30D-485A-ADB9-106ED584EDA8.jpeg 764E4B96-2F81-43E0-9900-E9AB101ED3AA.jpeg
    Jet96 and Bob Lowry like this.
  20. GCDC
    GCDC
    What do you have on fronts ?
    Rim width on back 4-1/2?
  21. continentaljohn
    continentaljohn
    Yes rim width in rear is 4.5 and run 5:50 highboy and 6:00 on a fender car . I also try to run 4.0 rims in the front with the 5:50 if I can find them. The 4.5 rims is ok with the 6:00 and unnoticeable on what your width is. B4EBFC60-1AD5-4304-B46B-7B3A344F0571.jpeg
    GCDC likes this.
  22. GCDC
    GCDC
  23. GCDC
    GCDC
    This has 5.25 on front . You think this is 750 on back?
