Rear Traction Bar Installation
Discussion in 'The Hokey Ass Message Board' started by Humboldt Cat, May 1, 2004.
  1. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Am trying to install rear trac bars from Summit that came with no instructions (and haven't been able to acquire any).
    Anyone know how, or have pics of theirs attached to the springs? Or maybe there's been a tech on it. Or would anyone like to see a tech on it?
  2. plan9
    plan9
  3. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Thanks, Plan9! Actually, that's for a rear trac link bar. This is the universal Lakewood setup I'm working with:
  4. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    I think I'm in th process of finding out how easy it is (and how dumb I'm about to feel), except I'll need to get longer U-bolts. Anyone have pictures of 'em on their ride?
  5. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    ...but then simplistic looks can fool ya. Just trying to make sure I'm on the right track. Just need longer U-bolts, first.
  6. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I do not recall anyone using this setup on a rear that was mounted below the spring. I have never had an application like this myself and I do not recall looking at one that was set with these bars and a rear mounted below the spring. Seems like you need a different style traction bar.
  7. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Hmmmm... will have to call them 'bout that. Thanks for the tip. Had a co-worker with a '69 Mustang with a similiar rear leaf set up, with similiar trac bars. Damn, I shoulda took pics when I knew her. Ok... thanks for the tip! I'm beginning to feel dumb... y'know that sense, as it's approaching? Yep.
  8. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Thought I'd continue to give it a shot, yesterday... after a run to Ace for longer U-bolts, and tying the rear break line to the frame, I got concerned this line will end up pinched in action, between the bars and the frame, but have nowhere else to steer the line out of the way. What do you think?
  9. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Other side looking in...
