Technical Rear U-joint retainers '55 Ford
Discussion in 'The Hokey Ass Message Board' started by 38fordpickup, Jul 31, 2022.
  1. Is there some special tool for unbolting the rear U-joint retainers on my '55 Ford. They appear to be 1/2" heads but I can't get any kind of open end or box end to grip them. They haven't been touched since about 1968.
  2. If it's the Strap style instead of U-Bolt style, I believe the bolt heads were 3/8" not 1/2". I have never had to use anything that isn't normal in my Tool Box.
  3. IIRC, those have a sheetmetal 'washer' under them with locking tabs that are bent up against the bolt heads. Clean off the bolts and bend the tabs away from the bolts. Then you can get a wrench on them...
    dirt t, Bob Lowry, RICH B and 4 others like this.
  4. I totally forgot about the Old Locks. One-piece locks 2 bolts. No lock washers as we know them.
  5. Mr48chev
    the lock straps look like this. those tabs are bent up against the flats on the bolt. It'ds probably been 50 years since I change one of those. ford U joint lock strap.jpg
    Pist-n-Broke, Bob Lowry and egads like this.
  6. squirrel
    and they're probably not "retainers", they're probably the bearings, with their mounting ears.
  7. guthriesmith
    guthriesmith
    Yep, most expensive u-joint I think I have ever bought for a car...
  8. jimmy six
    jimmy six
    Someone told me they were called “mechanics” style U-joints. They have been referenced here before..
    seb fontana likes this.
  9. 51504bat
    51504bat
    Also referred to as bat wing style U joints.
