Technical Rear wheel hub ( outer race - pitting) still ok or not?
Discussion in 'Traditional Hot Rods' started by V8-m, Nov 18, 2024.
  1. V8-m
    V8-m
    from Alaska
    Hello guys,
    I took the hubs off my banjo axle for inspection and saw corrosion damage in one place. Apart from that, the rest of the bearing race is in very good condition. The bearing itself, which is original Ford, also has pitting on two rollers. The bearing is in very good condition apart from the mentioned place with corrosion. Is this set suitable for further use? The wheel hub is from 1948. It does not appear that the outer bearing race can be replaced. I've seen such repair kits somewhere, but not for 1942-48 hubs.
    Regards
    IMG_20241118_210627.jpg IMG_20241118_210552.jpg IMG_20241118_210718.jpg IMG_20241118_210727.jpg
  2. TCTND
    TCTND
    That's just going to get worse, and as it does, the rate of deterioration will continue to increase.
    dirt t, Johnny Gee and V8-m like this.
  3. Budget36
    Budget36
    Replace the bearing and race. Mac Van Pelt sells quality parts, check his website.
    V8-m likes this.
  4. Jmountainjr
    Jmountainjr
    Looks like it sat in one place with water in the hub. The pitting is through the hardened surface, so it will continue to wear. It depends on how long you want it to last will determine if you should put it back together with that bearing.
    V8-m likes this.
  5. jaracer
    jaracer
    That is suitable to leave you stranded on the side of the road. That is worse than pitting, it is the beginning of spalling where chunks of metal break out.
    Truckdoctor Andy and V8-m like this.
  6. lostone
    lostone
    from kansas
    Replace !!
    V8-m likes this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    lucky that you caught it when you did. better to replace now than on the side of the road....
  8. 1biggun
    1biggun
    Junk. Replaces it and be glad you caught it
  9. Tim
    Tim
    from KCMO
    Ok so now he’s going to ask how to replace the outer bearing race. Someone want to point to a thread or video answering that?
    V8-m likes this.
  10. V8-m
    V8-m
    from Alaska
    No problem I can handle this job only need to know if it's removable.
    firstinsteele likes this.
  11. Budget36
    Budget36
    I’ve never done a rear hub on a banjo rear, but should be a spot(s) to get to with a drift punch.
  12. V8-m
    V8-m
    from Alaska
    I can heat it up with TIG on couple of places and it should shrink enough to make it easier to remove.
    irishsteve likes this.
  13. Budget36
    Budget36
    Look through the back of the hub, any spot to knock it out? Small lip on the race, slight cutout, etc?
    But I’ve never welded on a bearing race, I know it’s done on Cummins steel liners, but don’t know the process used. I’d think you’d weld, let it cool???
  14. alchemy
    alchemy
    It’s not replaceable. Get a better hub.
    warbird1 and V8-m like this.
  15. seb fontana
    seb fontana
    from ct
    I bet the axle housing [inner race] doesn't look too hot either?
    46international likes this.
  16. alchemy
    alchemy
    I’ve disassembled many rearends, and usually the hub is fine but the housing is bad. This one might be the opposite.
  17. V8-m
    V8-m
    from Alaska
    Bad news....
  18. brading
    brading
  19. alchemy
    alchemy
    Huh. Learn something new every day.
    brading likes this.
  20. squirrel
    It would be fine for short trips, but I wouldn't try a LeMons Rally with it.
    arse_sidewards likes this.
  21. dmar836
    dmar836
    Don't go heating it up with a TIG torch. That would distort the concentricity for sure. Isn't it one piece anyway?
    If you can find a hardened sleeve(race) I would assume the hub would need to be turned and the new one pressed in. Still, I would wonder how concentric it would remain with an interference fit.
    I'm even concerned with facing hubs for new drums as I'm not sure how I will hold them. The hub is a rough casting on the OD, no?
  22. Tim
    Tim
    from KCMO
    If a guy got the race out are they available to purchase? Some creativity can always get one out but finding something to replace it with is another thing.
  23. 1935ply
    1935ply
    from peyton,co
    These races are not replaceable, you will need another hub. If the axle housing is worn or pitted you can have it turned down and a sleeve pressed on it. Not a small job and takes a big lathe. I think even speedway sells repop hubs if you can't find a good used one.
  24. alchemy
    alchemy
    What drum are you planning on using with this 48 hub? Or are you sure it’s a 48 hub?
  25. RICH B
    RICH B
    Pretty sure that the 68-1236 sleeve being mentioned is for use in repairing earlier larger ID hubs ('28-'36 I think) and permit use of the later small OD axle bearings.
    Edited the year range as the large bearing was used up to '36.
    Tim likes this.
  26. RICH B
    RICH B
    Maybe one of those nifty Industria Argentina drums.
    Picture does looks like an outside flange hub.
    I'd look for something better to start with.
    Tim likes this.
  27. V8-m
    V8-m
    from Alaska
    I think I have found solution...
    Bearing which is almost identacal O.D. with hub O.D. a little bit machining and it should press fit inside the hub.
    The inner race can be used as sleeve for axle housing.
  28. brading
    brading
    V8-m and Budget36 like this.
  29. V8-m
    V8-m
    from Alaska
    No matches found for this number on ebay
  30. Budget36
    Budget36
    Here’s a recent (2 years old) thread on the FordBarn, read through it. A member mentions he started reproducing the sleeves 25 years ago.
