1952-59 Ford rearend 8.8 disk brake
Discussion in 'Off Topic Hot Rods & Customs' started by BeerMoney, Apr 13, 2021.
  1. BeerMoney
    BeerMoney
    is there a rearend 8.8 disk brake that is a bolt in for a 55 ford customline
  2. Keith Sweesy
    Keith Sweesy
    from Hope, Ar.
    I posted one from the ranger station a couple post down. There’s a link there for mustangs that’ll bolt onto a 8.8.
  3. ffr1222k
    ffr1222k
    An Explorer rear with two of the short side axles is the right width and from 1995 to 2002 is disc brake.
  4. 2dasand
    2dasand
    Don't you have to cut the housing to use two short side axles?
  5. jimmy six
    jimmy six
    That’s what ffr222k said. There are at least 3 you tubes showing how to do it. There are lot of other brackets remove and grind smooth. You also can grind or saw off a lot of the center housing that’s no longer needed. A yoke is available to make a standard u-joint fit your drive shaft. I had a new one made.
    ffr1222k likes this.
  6. Black Wagoon
    Black Wagoon
    Local differential shop quoted me @ $250 to narrow the long-side 3".
    Rear End cost $200 at my local pick-n-pull with a 3.73 LSD and an extra short axle.
    JeffB2 likes this.
