Rearend for 36 Ford car
Discussion in 'The Hokey Ass Message Board' started by 47chevycoupe, Aug 1, 2011.
  1. 47chevycoupe
    47chevycoupe
    from Finland
    I know that someone has asked this question before. Did the search for about 2hrs and have not found any info. I **** at this computer ****.
    What width is the stock rearend in the 36 or what rearend is a good fit.
    Plan on using a 7" wide wheel on back with a 225/75-15
  2. 325w
    325w
    I used a 67 Fairlane. Ran 7 inch Americans
  3. Johnny Speedster
    Johnny Speedster
    from Atlanta
    96-2001 ford explore or mountaineer rear 4x4 (373, limited slip, 8.8, disc)
  4. ravedodger
    ravedodger
    I have what I believe is an original 36 rearend. I measured outside of drum to outside of drum (where the face of the wheel touches the drum) at 57" and flange to flange at about 52.75"--accounting for bend in tape caused by banjo. Of course the pics won't line up with exactly where I measured.
  5. The 57-59 Ford p***enger cars have the narrowest nine inch,they fit perfect under the early cars.I think the early 70s Ford Broncos are narrow also.
  6. bscottstudio
    bscottstudio
    from Kansas
    Bingo, best option for looks and fit .
  7. CharlieLed
    CharlieLed
    Now all you have to do is find one...
  8. 47chevycoupe
    47chevycoupe
    from Finland
    Thanks for the info.
    Called a few salvage yards for the Explorer rearend. Cheapest was $350. had 204K on it. $750 with 90K.
    Found a 72 Bronco rearend $500. I am a tightwad as these seem high to me.
  9. SMOKINFLATHEAD
    SMOKINFLATHEAD
    from SOCAL
    That does seem HIGH, got my explorer rear from a pick-a-part for $250.
  10. carlos
    carlos
    from ohio
    Got 1959 ford 9 incher with 15x 8 chrome reverse on mine with 8-20 silvertowns on mine ,perfect fit
  11. Check craigslist. I found an 8.8 in my area for 100 bucks, complete!!
  12. Hitchhiker
    Hitchhiker
    You need to go to a pick and pull or find someone parting on online on CL
  13. Deuce Roadster
    Deuce Roadster
    TOO BAD you are not closer. They only cost $150/$200 in my area for the Explorer rear. NOW ... the Bronco is a different deal. They usually run $350 or so.
    Explorer rear ends are COMMON ... :) But I prefer the 57/58/59 Ford 9 inch for a early Ford. They are fairly common in my area also :eek:
  14. Johnny Speedster
    Johnny Speedster
    from Atlanta
    Explorer rears in Atl (less rear rotors) are less than 75.00 and just over a 100.00 with.
  15. Look for an explorer on craigslist that they want to get rid of and buy the whole thing. You may be able to use more then the rear.
  16. I don't know where in Missouri you are but if you can find a U Pull it somewhere close to you a tool box will save you a fortune in a late model rearend.
    Seeing as how you know that 57" flamge to flange is perfect a tape measure and a couple of straight edges in your tool box may find you a bunch of rears that are close to correct.
  17. 47chevycoupe
    47chevycoupe
    from Finland
    Wish I was close to you. With s**** prices so high, just about everything around here is gone.
    Did check out CL nothing close to me (no suprise).
  18. Phil 41 Chevy
    Phil 41 Chevy
    I am using one out of a 1993 blazer 4x4 , 342 gears , 75 bucks at junkyard
  19. ntxcustoms
    ntxcustoms
    from dfw
    Went a picked up a 57 truck 9" ford last night for $200. Found it on CL, I find that you have to search with different wording for the same item to find all the results. I don't think I've found one yet searching for 9". They are still out there.
  20. mitch 36
    mitch 36
    I put a late 70's Granada 8 inch under my sedan, with reversed 15x7 wheels ,the 235 -75's fit real nice in the wheel openings. Mitch
