1952-59 Ford Rearend Help
Discussion in 'Off Topic Hot Rods & Customs' started by 53Flathead, May 31, 2014.
  1. 53Flathead
    53Flathead
    from Kansas
    I know there is a FAQ about this and was a recent post I thought. I am trying to find out what Maverick years are a direct bolt in for a 53' Customline. I remember it has to be a 6 cylinder but cant remember years. I am hoping I just hit the jackpot on a rearend swap.
    Thanks in Advance,
    Will
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Wrong,you want the 8 cylinder rear not the six. Maverick rears are getting hard to find 1988-92 Ford Ranger 8.8 are stronger and many have Posi and use the same bolt pattern and are a lot less $$.Use the search icon in the upper left and type in Ranger 8.8 and you will find a lot more info.
  3. RF Man
    RF Man
    from Topeka,KS
    Hey Will---most Maverick's have 8" rear ends in them regardless of whether they're 6 or 8 cyl. But like Jeff said a Ranger rear may be a better choice----hard to find a posi 8" in a Maverick---more common in a Ranger. Jeff is the 8.8 Ranger a direct bolt in?
    Mike
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    Both the Maverick and the Ranger rears will require some tweeks as they will use a different U-joint at the rear from our early Fords.This picture shows an 8.8 installed in a '53 Ford with lowering blocks. \'54 8.8 rear.jpg
