Rearend
Discussion in 'The Hokey Ass Message Board' started by Inline6, May 14, 2008.
  1. Inline6
    Inline6
    anyone know what kind of rearend that will bolt right up to a 51 gmc truck i want somethin with better gears and an open driveshaft
  2. Mr48chev
    What lug bolt pattern?
    We put a 56 1/2 ton in a 53 and it fit well but it wasn't a bolt in. I don't believe anything is a direct bolt in.
    You either have to move mounts or weld on the Moroso style mounts and drill a new locating hole to center the axle in the wheel well.
    Under my 48 I have had
    61 Impala axle with all the brackets trimmed off and Moroso mounts welded on. I ran 15x7 67/69 Z28 Ralley wheels with that and they fit great.
    68/70 something Nova with the same mounts welded on. This is too narrow to run wheels that don't have a lot of back spacing.
    Late 60's Impala 12 bolt. Again you have to clean all the brackets off. I ran it as a 4 link setup with coils. The width is good for most rims that are 8 inch or less wide.
  3. RT1
    RT1
    Check over here http://www.stovebolt.com/ they have just about everything covered. I think a lot of guys use S10 rears.
    :cool:
  4. Inline6
    Inline6
    k yea i want sumthin with the 6 bolt lugs
  5. 53sled
    53sled
    from KCMO
    60s Chevy/GMC would be closest to a bolt in, but still not really. Toyota/Mazda mini trucks may be the correct width, and you can add perches. They are not too expensive.
  6. 55 dude
    55 dude
    toyota is a good choice, cheap and strong and has axles with bigger dia. than a 9" ford.
